Old 06-21-2002, 08:46 PM   #1
tradewind holding tank
I just discovered my bargain 68 tradewind has no holding tank. Where can I get one?
McGill is offline   Reply With Quote
Old 06-21-2002, 10:22 PM   #2
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Welcome McGill and congratulation on you first Post.
If you are referring to the grey water tank (sink and shower waste water), Airstream did not put these tanks in until 1973. You will either have to purchase a portable tank. These tanks are available in sizes starting at 5 gallons on up to 32 gallons.
If you are staying in a proper RV park, you just hook up to the sewage system and drain away.
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 06-22-2002, 12:17 AM   #3
66TradeWind's Avatar
Images: 22
ank sources
You could try Inland RV or All Rite RV (click on products and you will find holding tanks)
Terry O'Neill
Calgary, Alberta, Canada
WBCCI 4786
VAC
http://pages.sprint.ca/Streamsite/main.html
66TradeWind is offline   Reply With Quote
Old 06-22-2002, 09:28 AM   #4
Well, all the old plumbing was frozen and some guy lived in the trailer for 10 years in a campground.
I'm redoing all the plumbing and putting in a holding tank for toilet and sink waste.
I'm a lanlord so this is like a mini apt remodel.
That pesky grey water that bypases the holding tank Van All Argosy Trailers 15 08-13-2004 07:52 AM
Pulled the plug out of the Holding Tank? ssolid Fresh Water Systems 0 03-24-2004 11:13 AM
Holding tank warming TomW Repairing/Replacing Floor &/or Frame 5 01-07-2004 11:03 AM
Holding tank plumbing question yukionna 1997 - 2004 Bambi 15 09-10-2003 08:00 PM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 03:40 AM
