Old 01-12-2015, 07:44 PM   #1
kellykellyi's Avatar
1952 15' Cruisette
1967 20' Globetrotter
2010 19' International
La Cañada Flintridge , California
Toilet to nowhere...Say what?
I just purchased a '52 Cruisette that has a toilet hidden under the dinette bench but it goes to nowhere. Just outside! No space for a black tank where the toilet is located and since it's likely been there for more than 60 years, I am hoping someone has seen this "setup" before and can advise on what would have gone under the trailer to make this toilet operable? Eww, I know but the question has to be asked!
kellykellyi is offline   Reply With Quote
Old 01-12-2015, 07:51 PM   #2
Wayward's Avatar
Cary , North Carolina
There was a thread on this a while back. Apparently early travel trailer campers would dig a pit in the ground and pull the trailer over it. Cover up upon pulling away.
Where did the poop go in 1952.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 01-12-2015, 07:52 PM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Kelly,
Before holding tanks were installed, the toilet had to be hooked up to a sewer system with a hose or dumped into a "rabbit hole". Now you can use a blue boy container or figure out how and where to install a holding tank.
Bill
Just my personal opinion
Old 01-12-2015, 08:13 PM   #4
1952 15' Cruisette
Well that won't work these days. Good grief!
Old 01-12-2015, 08:15 PM   #5
1952 15' Cruisette
Originally Posted by wkerfoot View Post
Kelly,
Bill
Thanks Bill! My preference would be holding tanks but as you can imagine in this tiny Cruisette space is quite limited. Fingers crossed something can be worked out.
Old 01-12-2015, 09:31 PM   #6
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Toilet
kellykellyi, In your trailer the correct term for how to use the open drop toilet was to dig a "Gopher Hole" and pull the trailer over the hole. The hole was then filled when the trailer was moved. This as you have observed was neither sanitary or these days legal! If you do not have room to install a Black Tank beneath the floor under the location of the current toilet then your current toilet must be replaced with one that does not require a black tank to be used. There are many different types that will fill this need for you. There are Marine toilets, Composting toilets, and Cassette toilets that can be used and emptied in a sanitary dump after usage. In this case you would be able to repair the sub-floor to close up the "open hole". Then too you could use any of these toilets in a different location in the trailer if you chose to! Google the different types of toilets above to see pictures and specs on these toilets. Hope this helps Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 01-12-2015, 09:36 PM   #7
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
If you think thats a problem...wait till you discover the 3inch frame and the single thickness end caps.
Old 01-12-2015, 10:40 PM   #8
1952 15' Cruisette
3" frame and single panel end caps? Nobody does anything about the single panel end caps, do they? And do all Cruisettes have them? Because this ones interior walls sure don't seem any different than any of my other Airstreams.
Watch out Melody Ranch! Make this too scary and you will see me tow it up to your place for a full frame off renovation.
Door to Nowhere? By the Bay Exterior Storage Compartments & Access Doors 18 08-07-2009 06:31 AM
Drain from nowhere? niftypkg Plumbing - Systems & Fixtures 10 02-18-2006 08:33 AM
Duct to nowhere walter1 Furnaces, Heaters, Fireplaces & Air Conditioning 5 12-17-2004 07:16 PM
Help and advise she died in the middle of nowhere saxonsraven Airstream Motorhome Forums 7 07-29-2003 07:10 AM
Wires to nowhere Craig Electrical - Systems, Generators, Batteries & Solar 3 10-01-2002 07:03 PM
