Old 05-24-2007, 03:37 PM   #1
1976 27' Overlander
Hackett , Arkansas
Toilet Removal?
Does anyone know how to properly remove a toilet in a 1976 Airstream Overlander? There seems to a bolt inside of the toilet's plastic casing that is impossible to reach. Thanks.
sugarloafin' is offline   Reply With Quote
Old 05-24-2007, 03:55 PM   #2
Radman's Avatar
1972 27' Overlander
Monterey Bay , California
Images: 129
There are several great threads that go into great detail on how to remove the ole throne. Good luck....
Radman is offline   Reply With Quote
Old 05-24-2007, 04:07 PM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
You'll need a 1/2" socket (long) and an extension. I use 3'8" drive. Remove the plug at the upper back and go in from the top.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Toilet Replacement 3Ms75Argosy Sinks, Showers & Toilets 22 02-18-2007 07:51 PM
Rear toilet platform rotten, now what?? MontanaArgy Cabinets, Counter Tops & Furnishings 9 08-14-2005 06:46 AM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 03:07 PM
toilet doesn't hold water.... Chuck Sinks, Showers & Toilets 12 10-08-2002 10:03 AM
Toilet valve problem Charles Q Treichel Sinks, Showers & Toilets 1 09-04-2002 10:59 AM
