Old 10-11-2010, 05:32 PM   #1
willyjay's Avatar
2010 27' FB Flying Cloud
Burnaby , British Columbia
Toilet paper clog
We purchased a new 27FB flying cloud earlier this year. However I seem to have a persistent clog of rv toilet paper in the black water tank where the toilet empties into this. The black water flush system doesn't deal with it. I have been using one of those plumbing rods but got into a battle earlier today with the valve on the toilet bowl bottom--valve lost so this will be a smelly and possibly expensive repair. That being said I have come to the conclusion that I am not adding enough water and/or chemicals to the black water tank and would appreciate any advice you might have.
willyjay is offline   Reply With Quote
Old 10-11-2010, 05:36 PM   #2
2005 22' Safari
Gresham , Oregon
Are you using RV TP?
sempi2 is offline   Reply With Quote
Old 10-11-2010, 06:11 PM   #3
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Main reason for the dreaded clog is starting off with little water in the holding tank.
I use no chemicals and Scott TP and have no problems but I start off with several gallons of water in the tank.
The pile can turn into what appears to be concrete. What I would do is put water in the tank to cover the pile add plenty of chemicals let set for a week or so then dump about 4 bags of ice in the tank and drive (pull) it around.
Garry
Old 10-11-2010, 07:04 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Always start with about 10 gallons of water in your black tank. I usually carry a utility bucket to accomplish this, pouring water in through the toilet. Paper will then float away rather than become a stalagmite under the hole. That stalagmite has come up to just under the stool before my black tank has been less than half full. Start with that 10 gallons in the tank -- the remaining 30 gallons almost takes weeks to fill up.
Don't drain dry constantly if you happen to have a sewer hookup at a campground. You should mostly fill the black tank before you dump it. The gray water always fills and takes you to the dump station first anyway. Moving around and jostling the contents counts for a lot. There is no simple solution if you're staying parked at the same site for months at a time.
garry has the answer. Avoid the plushy paper. I don't use the $6/two-pack RV paper either. Thanks to thecatsandi I have gotten onto the Scotts one-ply bandwagon. Take one sheet of any paper you usually use at home. Take one sheet of Scotts one-ply. Put each in a separate bowl of water and observe. The results will guide what your use ever after. I'll bet it's the Scotts one-ply.
You can knock down the stalagmite by putting in 10-20# of ice cubes just before traveling a significant distance down the road. That will knock apart the stalagmite before it all unthaws (a Minnesota-ism of dubious meaning ). But I've had trouble knocking apart bags of ice small enough to fit down the toilet hole. Best to avoid this.
5 meter Langford Nahanni
Old 10-11-2010, 07:14 PM   #5
In the case of modern 40 gallon tanks that is. Or use a similar amount equivalent to about a quarter of your black tank.
Old 10-11-2010, 07:35 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
Well if it were me I would don a face shield, goggles, rubber gloves, and get out the lye.
And plan on replacing the seals on the dump valve.
Old 10-11-2010, 08:44 PM   #7
2002 19' Bambi
Lafayette , California
Our 2002 19' Bambi has a 6-gallon blackwater tank, so no adding extra water for us! We have a two-fold solution for the TP problem.
First is a Sewer Solution which sucks the blackwater out and allows, with our setup, backflushing.
Second is a length of plastic pipe with a threaded connection on one end and a cap with several small holes in it on the other end. The thread matches the one on our shower hose. After emptying the tank with the Sewer Solution, we take the shower head off its hose, screw the hose to the pipe, turn the water supply to the toilet off, open the valve, insert the pipe through the toilet valve into the tank (not completely to the bottom), turn on the shower water, and spray away. All the TP goes into the large pipe draining out of the tank and can be easily pumped away with the Sewer Solution.
Tim
Tim A. is offline   Reply With Quote
Old 10-11-2010, 09:22 PM   #8
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
The key as noted is to dump your black water tank as full as possible. And if it isn't, then fill it prior to dumping it. I've never had a clog and have used all kinds of TP. So if we are on a weekend outing, and it's time to go home, we fill the tank.....even if we don't create the material to fill it with!
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-11-2010, 09:51 PM   #9
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
As has already been said, use lots of water. I lived in a SOB for 3-4 months a year,for 3 years and never had a problem. I always added water after I emptied the tank, and I always allowed the tank to fill before empting. Adios, John
Diesel1 is offline   Reply With Quote
Old 10-11-2010, 10:30 PM   #10
withidl's Avatar
2002 31' Classic
Houston , Texas
Assuming your black and grey tanks have a common manifold, as stated above fill the black tank prior to dumping (I do so by partially depressing the flush valve such that water fills the bowl to the top rim but the valve doesn't open; then I fully depress the flush valve and suddenly purge the entire bowl; all while the black "sprinkler" is on). Then dump the black tank until it stops flowing, raise the "slinky" above the tank level with one hand and open the FULL grey water valve for about 5 to 10 seconds which will back-flush the black tank via the manifold, then close the grey valve and lower the "slinky" to allow the black tank to drain again. This can be done several times if the grey tank is FULL.
After the above proceedure turn off the "sprinkler", close the black valve and open the grey valve to purge the "slinky".
I've done this for the past 9 years and have never had any blockage while using ordinary toliot paper (I have never used RV paper).
withidl is offline   Reply With Quote
Old 10-12-2010, 12:13 PM   #11
cclarkego's Avatar
1966 24' Tradewind
Oak View , California
Images: 8
I have a 1966 Tradewind with only a black tank. Is there a good trick to figure out how full the tank is so it doesn't back up in my shower again?
Carol
cclarkego is offline   Reply With Quote
Old 10-12-2010, 06:33 PM   #12
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Carol
The black tank is separate from the grey water (shower). Grey water should flow out of the trailer unless the outside cap is on.
You can visually check the level in the black tank when you flush.
Richard
Old 10-12-2010, 09:41 PM   #13
willyjay's Avatar
Thanks to all of you for this info
Old 10-12-2010, 11:12 PM   #14
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Carol
Older vintage eh "charm of a '66" ? NO gray tank!
Early A/S models often were set up to have the gray drain directly onto the ground. This is no longer acceptable due to the increasing use of campsites. There is a lot of "funk" even in gray water.
Some people have added gray tanks, others carry a "blue boy" portable tank, in your case it appears that a PO routed all your plumbing into one tank. Black tanks on old units are really too small to be combo tanks.
Tank sensors --- mine work, but many malfunction. Sure method, take a flashlight, open the flush valve on the toilet and LOOK. A bit whiffy... but less offensive than having stuff in your shower!
I'd peek under the belly pan and see how much re-routing was done. Perhaps it wouldn't be major to change back to a separate gray drain and carry a 10-15 gallon blue boy.
Paula
Toilet paper recommendations??? crazylev Sinks, Showers & Toilets 15 11-25-2010 04:59 PM
Toilet paper....?? THEPILL On The Road... 24 06-30-2010 05:17 AM
Best price on toilet paper sharptalk Plumbing - Systems & Fixtures 16 07-22-2009 05:32 AM
Toilet paper and other things campcollector Waste Systems, Tanks & Totes 45 12-08-2006 09:22 PM
Toilet Paper: Is scotts ok? TBKP's Overlander Plumbing - Systems & Fixtures 11 11-29-2002 08:03 PM
