Old 06-04-2015, 08:28 AM   #1
DuncanK1's Avatar
2015 30' Flying Cloud
Berrien Springs , Michigan
Toilet Paper!
Apologies - down to basics here!
I'm a boat captain and I've had my fill of blocked toilets. Some boat owners in Europe go as far as demanding everyone use a bin for papers (yuk).
Now I have an Airstream I'm wondering about such practicalities. Does everyone use the specialized paper like Thetford Quick Dissolve RV Toilet Paper or is regular paper just fine?
DuncanK1 is offline   Reply With Quote
Old 06-04-2015, 08:31 AM   #2
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Angel Soft breaks down easily and is 2 ply.
Put some in a bottle of water and shake it and it breaks up fast.
Kelvin
Old 06-04-2015, 08:47 AM   #3
batman's Avatar
1964 22' Safari
modesto , California
Angel Soft 2ply double rolls, every day.
batman is offline   Reply With Quote
Old 06-04-2015, 08:56 AM   #4
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Using single ply or angel soft 2 ply will insure no trouble from TP. Keep your black & Gray drains closed all the time until ready to dump & no solids will build up in your tanks.
Mrjkq is offline   Reply With Quote
Old 06-04-2015, 09:09 AM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
No reason to buy the high priced packages marketed for RV use. Any brand on your grocery store shelf marked "safe for septic tanks" will work just fine.
MICHAEL
Old 06-04-2015, 09:26 AM   #6
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
After an early toilet paper issue with Old Lucy, I went to the Camco 2 ply RV toilet paper. The RV stuff is pretty expensive at $4.64 for a four pack at Wal-Mart. I think that I will get some of the Angel Soft and give it the "dissolve in water" test.
Admittedly, I'm a bit gun shy after my early experience with non-RV toilet paper.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 06-04-2015, 09:48 AM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Well, please do NOT flush the "flushable" ones. Even in the public systems they are causing huge issues. So, if dissolves easily, ok for RV. Make sure you have plenty of water in the black tank to handle the "flow" needed to empty the tank... Rinse at least twice...
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-04-2015, 10:42 AM   #8
1968 24' Tradewind
Carlsbad , California
There's a test done on the fitrv.com site. RV Toilet Paper Test from The Fit RV - now with children! He also tests black tank myths as well as other rv related topics. informative site.
shilgemann is offline   Reply With Quote
Old 06-04-2015, 10:49 AM   #9
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
I remember when candy bars were bigger bars, they are doing the same to TP rolls, have you noticed it doesn't fill the bar on holders. Maybe they are trying to help you cut back on amount used and less problems with holding tanks
CG's have garbage, recycling and even specialty bins for propane tanks and Aluminum cans but no hazardous waste containers.
For Gulf Coast Oil filter users you will not fill the space with the new narrow width size rolls.
Old 06-04-2015, 10:51 AM   #10
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
We've used RV and regular paper. Either seem to work about the same, but I backflush the system regularly and that gets everything out, dissolved or not. I don't think the RV paper is worth it—it doesn't seem to dissolve any differently than regular paper. Using a Flush King for backflushing means you can see what comes out (always a joy) and I don't see a difference.
Gene
Gene
Old 06-04-2015, 11:12 AM   #11
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
I have a small clear extension on by tank discharge into the Sewer Solution and use any of the "safe for septic system" brands from the market. I will take Kelvin's suggestion and do a jar of water test in the future.
As Gene noted, the clear section provides an inspection port so I can see what my tank sprayer is, ahem, flushing out of the tank. Some paper is still kind of intact but wispy, and have not had any clogs...yet,
Cliff & Andrea,
2 cats, but they stay home
TerraYacht is offline   Reply With Quote
Old 06-04-2015, 11:37 AM   #12
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Only use RV paper. Have used others, but as Terra does I use a clear section on the dump hose so I can monitor what is happening. When I "tested" the papers and used septic safe toilet paper from Walmart, much of it was still in tact after four days. When dumping the RV paper, most of it has already been dissolved after the same period. Not a scientific study but convinced me as I do not want a clog of any kind.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 06-07-2015, 11:46 AM   #13
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Hmm . . . and interesting, if somewhat yukky. Good to know. We've used regular house TP for the past three years and don't seem to have a problem (at least that I know of). The Sewer Solution is a great help, I'm fairly certain. I appreciate Brian's post and will try both of those brands.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 06-07-2015, 12:05 PM   #14
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Walgreens "Big Roll"
Best price on toilet paper sharptalk Plumbing - Systems & Fixtures 16 07-22-2009 05:32 AM
The Great Toilet Paper Debate moosetags Sinks, Showers & Toilets 26 02-19-2008 08:59 AM
Toilet paper and other things campcollector Waste Systems, Tanks & Totes 45 12-08-2006 09:22 PM
Important papers: toilet paper cover Safari64 General Interior Topics 15 03-17-2006 07:04 PM
Toilet Paper: Is scotts ok? TBKP's Overlander Plumbing - Systems & Fixtures 11 11-29-2002 08:03 PM
