Old 12-13-2007, 07:15 PM   #1
1999 25' Safari
Sebastopol , California
Toilet not holding water for #2
It seems like the toilet in my 1984 Excella is not holding water when I step on the peddle. It just exits past the plastic that slides across the tank opening and whoosh. So, no water builds up in the toilet for the inevitable #2.
Is this a common problem that I can repair or is it time for a new toilet.
Aluminumb is offline   Reply With Quote
Old 12-13-2007, 07:24 PM   #2
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Yes, it can be repaired, it's a Theford, yes.
There is a rebuild kit.
Now some say for the price difference you should just get a new one, me, I rebuilt mine.
I learned things. Of course the things you learn some may not want too
Michael
ArtStream is offline   Reply With Quote
Old 12-13-2007, 07:53 PM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Try this first
In an 84, your seal is probably gone but you might also have built up scale from hard water or some other biological matter.
Get your trusty rubber glove, some baking soda and a piece of old cotton double knit from a T-shirt, etc. Get the rag damp and pour on a generous amount of baking soda - which is a non-abrasive cleanser. I have the dreaded plastic bowl in my '06 and I know it's cheap crap I'll have to replace in a couple of years, but to avoid even more premature failure, baking soda will clean the whole bowl without scratching or staining. BTW if your stainless steel silverware looks dingy, this is great way to make it shine like new. Uh fellas.... use a different rag for the silverware, the one you use for this chore gets thrown OUT! (.... sorry I have a nephew who really does need that last instruction. )
Kneel, open the trap and thoroughly rub all sides of the lower end of the toilet bowl, and the slider. Let the trap partially close on the rag and gently pull it back and forth. When you're finished, rinse with the sprayer or a couple of cups of water. Then see if it will hold water.
If not, it's time for a rebuild or a new throne.
Good luck, Paula
Old 12-13-2007, 08:31 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Also check that the slide is sealing correctly. Sometimes paper gets pushed into the area where the slide seats and prevents it from sealing. You can check it with a small mirror and a light.
Richard
Old 12-13-2007, 08:47 PM   #5
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
You forgot to mention the high power magnifying glass
Michael
Old 12-14-2007, 10:04 AM   #6
1999 25' Safari
Great, I'll try the baking soda today. Thanks for all the comments from everyone.
Old 12-14-2007, 10:23 AM   #7
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
You can also try CLR which removes lime and scale, worked great for me. Just add to the bowel let seep/set and brush with the valve open/closed.
jkcru is offline   Reply With Quote
Old 12-14-2007, 11:05 AM   #8
HowieE's Avatar
Princeton , New Jersey
Images: 12
As noted above most often it is paper that has become trapped in the seat of the valve. Take a stiff coat hanger open it to make a wire and bend the end about 1 in. at 90 degrees. You can bend the other end to use as a handle, you now have a Z bar. While holding the valve open try useing the hanger to clean the groove that the valve seats into. If it is clean you should feel nothing. If paper is jammed in the seat you should hit it and be able to dislodge it.
2004 Excursion 4x4
Old 12-14-2007, 11:06 AM   #9
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
This most likley the trouble,toilet paper. Blade valve catches the TP between blade and seal, that then will not let the valve go closed all the way.Mine got so bad I had to take toilet out to cleane out the TP at the seal and valve.Removing toilet ,cleaning valve and putting back took about 30 min.Some say you can use bent screw driver and reach in and get it out. Mine was packed in to hard.
Jimmini :
AKA : TUMBLEWEED. Just an old buzzard with a itch to yonder.
Cowboys have a way of looking at things a little differently than most folks.Their wisdom is simple and more down to earth.
jimmini is offline   Reply With Quote
Old 12-14-2007, 11:26 AM   #10
1983 30' Airstream 300
Plantersville , Texas
Good luck in finding your problem. I repaired mine last year. I put a new gasket kit in it. works great. I bought a new thedford toliet and when I started to install it, I found that the bolt pattern was different, Not wanting to try to move bolt placement I returned new toliet and got the repair kit.
kay
carnegie1935 is offline   Reply With Quote
Water leak from Holding Tank Drain gwilliam Fresh Water Systems 5 04-18-2010 06:45 PM
Really need a drain on the fresh water holding tank?? SmokelessJoe Fresh Water Systems 16 06-17-2007 07:50 AM
Fresh water and holding tanks tslanier Waste Systems, Tanks & Totes 2 06-04-2007 11:00 AM
Explain the water/holding tank system to me? truebebeblue Waste Systems, Tanks & Totes 2 03-25-2006 05:07 PM
no gray or black water holding tank pahadley LP Gas, Piping, Tanks & Regulators 8 11-11-2004 07:11 PM
