Old 11-28-2010, 07:07 AM   #1
1979 28' Airstream Excella 28
boynton beach , Florida
Images: 20
Exclamation Toilet Flange Removal trouble
We are having such trouble getting the flange out of the toilet, WE have tried to use leverage. liquid wrench, the thing won't budge, thinking we might have to cut the whole thing out and replace it... Any suggestions?
nikiarntz113 is offline   Reply With Quote
Old 11-28-2010, 07:11 AM   #2
Cutting an old toilet flange out, is very common.
They are not very expensive to replace.
Old 11-28-2010, 07:48 AM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Took mine out yesterday with the info found here, used two self tapping screws at the distance of flange holes into a 2x2, broke a screw with leverage, put in another one deeper into the wood, it had caulk for about an inch of thread, it was still gummy and well stuck. According to notes in file it was installed 7 yrs ago.
Old 11-28-2010, 08:02 AM   #4
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
I used this same method to remove the flange in my 1967 Tradewind. Mine appeared to be original. Adios, John
Diesel1 is offline   Reply With Quote
Old 11-28-2010, 08:12 AM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I made a spanner wrench. Took a piece of steel flat stock about a foot long. Drilled and tapped holes in it spaced the same distance apart as the slots for the toilet bolts; held it down tight with one hand and turned it loose. It was pretty tight. I had removed the cabinet next to the toilet so had plenty of room to work.
Old 11-28-2010, 11:03 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
OOPs!
I forgot to say that I screwed bolt in each of the holes I tapped. So it looks like there are 2 pegs sticking down from the bar. The pegs go into the holes where the toilet holdown bolts were.
Old 03-23-2011, 09:28 PM   #7
Nukeblade's Avatar
1991 32' Excella
Deltona , Florida
Images: 14
Toilet flange spanner wrench;
see the screws in the board above the toilet flange
The flange came out easily and you can see how it fit on the "homemade spanner wrench"
Nukeblade is offline   Reply With Quote
Old 03-24-2011, 10:29 AM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Nice wrench
Looks like yours worked as well as mine; good job.
Old 12-20-2011, 03:25 PM   #9
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 117
Years ago I made a toilet flange tool but after I sold my Airstream, I got rid of the tool as well.
Today I reached that point in working on my "new 77 Sovereign where I needed to get the flange off prior to dropping the pan and tanks. So, I welded up another tool out of misc metal parts from old bed frames. Worked like a charm! One twist and the flange was freed with no excess pressure on the tank.
Notice the bed legs for twisting leverage....
My 77 Sovereign Renovation
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 01-13-2012, 03:58 PM   #10
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
same issue here
This seems to be a very common issue and I wish I knew about this magic tool before !
Anyways since the floor will be replace due water damage I got the whole black tank out with the part of the floor attached to the flange
Should we just cut the flange?
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 01-22-2016, 01:17 PM   #11
1973 31' Sovereign
McDonough , Georgia
Connector on top of black tank
Quick question...How do I connect my flange to the connector in the picture. I dont think this needs to be removed, but I cant find any way to connect my flange.
Thank you,
Amy
acoursey is offline   Reply With Quote
Old 01-22-2016, 02:16 PM   #12
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Thank you,
Amy
Attachment 256112
The metal ring part of the flange is missing, so you need to do a total replacement.
The ring shown at this website is what yours looked like before the missing part was removed.
http://www.wayfair.com/GenovaProduct...=1104000082717
Alan
Old 01-22-2016, 02:25 PM   #13
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
There is also a product called fix-a-flange, made to repair toilet flanges. It is a metal ring cut into sections, made to fit around the plastic part. This product will work if you have a wood base that is sound enough to hold screws.
Alan
Old 01-22-2016, 11:29 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Be careful using "fix a flange". The plywood on top of the tank is less than 1/2" thick. You do NOT want to penetrate the top of the black water tank with screws.
RV toilets do not use a wax ring to seal.
They use a specific rubber seal.
Do the research and do the job the right way. You won't regret it.
toilet replacement
Toilet mounting flange Green68 Sinks, Showers & Toilets 7 03-21-2011 09:21 PM
composite flooring bathroom installation sealing the toilet handn Floor Finishes 1 03-10-2011 07:47 PM
1968 22' Safari vinyl toilet cover wanted! dawnhugh70 Interior Restoration Forum 4 03-08-2011 06:21 AM
mounting toilet flange on black tank 386kustoms Sinks, Showers & Toilets 3 03-04-2011 08:52 AM
91 limited flange question tvanwave Sinks, Showers & Toilets 4 02-18-2011 05:46 PM
