Old 03-23-2014, 05:18 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
Toilet flange question
I posted a question under the Argosy trailer forum and hoping some of you can answer for me? It's listed as New toilet suggestions.
I need to know if the screws that hold the adapter and flange are simply going through a plywood subfloor or the tank itself?
I assume the tank flange has a bit of a neck to drop down and connect to the actual black tank therefore when I screw it down it will not puncture the tank?
Dan S is offline   Reply With Quote
Old 03-23-2014, 06:41 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
It screws to the plywood only. The tank is right below that. I would not screw thru the floor to be safe.
toilet flange joel Sinks, Showers & Toilets 0 03-15-2014 03:01 PM
Full timing and the eternal toilet question... racer155 Full-Timing 20 03-03-2012 07:33 PM
Toilet mounting flange Green68 Sinks, Showers & Toilets 7 03-21-2011 09:21 PM
mounting toilet flange on black tank 386kustoms Sinks, Showers & Toilets 3 03-04-2011 08:52 AM
91 limited flange question tvanwave Sinks, Showers & Toilets 4 02-18-2011 05:46 PM
