Old 03-16-2014, 04:25 PM   #1
1990 29' Excella
Long Island , New York
Toilet Flange & Tank Not Square
Ok, so I replaced the floor in the bathroom, valve leak and years of, well you know destroyed the subfloor. It was to the point that the toilet would move when you sat on it like a rocking chair. The floor was rotten especially behind the bowl, sothe plastic threaded neck of the tank is now in a permanent angled back position. I tried to put the flange back on but it crossthreads because its not square, you follow? Right now it is 30 degrees here, so I just put a u clamp in there, without the flange attached tohold it square with the subfloor, and am letting it sit. The only thing I can think of is maybe filling the tank with hot water to maybe make it more pliable? Any ideas?
Jeepjunk4 is offline   Reply With Quote
Old 03-16-2014, 05:47 PM   #2
1990 29' Excella
Got it! I will take apiece of rope and tie it in the middle of a piece of wood or metal and drop it vertically into the tank. Then when its in the tank I will turn it horizontally, pull on the rope, square it up, and tighten the flange. done.
Old 03-16-2014, 05:51 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Not quite done. Figure out how you'll get it back out again, too. Unless you want a piece of wood floating in your tank all the time.
My suggestion— before dropping it in the tank, attach a second piece of rope to one end. Leave that rope slack. Then, once you're done, let go of the first rope, and pull the wood back up by the second one.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Grey tank for rear bath '66 TW. FreshAir Waste Systems, Tanks & Totes 15 02-13-2012 09:06 PM
Gray Water Tank Flush Road Geezer Waste Systems, Tanks & Totes 6 02-01-2012 06:23 PM
Toilet and Tank Vent pipe plcement chromis Sinks, Showers & Toilets 1 01-16-2012 06:10 PM
I am having problems removing flange from black tank bennyg Waste Systems, Tanks & Totes 11 07-08-2011 07:19 AM
Closet flange and new cork floor. desertair27 Sinks, Showers & Toilets 3 06-17-2011 04:10 PM
