Old 07-27-2015, 08:37 AM   #1
Growing old but not up
1972 29' Ambassador
St. Louis , Missouri
Toilet flange
I've pulled the black water tank on my 72' Ambassador for the floor replacement and the toilet flange looks like it's glued to the tank. I want to lay one sheet of flooring down so I'm thinking I have a delicate removal of the flange to reglue a new one. Is there a flange kit for the tank or is this my only option. Thanks in advance.
riskstl is offline   Reply With Quote
Old 07-27-2015, 08:54 AM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
On a 68 the flange screws into a short nipple that is in turn screwed into the threaded fitting on top of the black tank. Mine was a bear to get loose. I think yours will unscrew as well after you take the screws out that hold it to the floor. I tried tapping mine off with punch on the edge but had no luck. I finally got a piece of steel about 2 feet long x 1 inch wide and drilled holes in on end to match the flange bolts that hold the toilet down (a board might work but I had steel handy). I screwed it down on the fange and with the added leverage the thing just unscrewed with no problem. Getting it to beak loose is the issue, after that is just unscrewed. A 72 may be different but that is how I got my flange out. Another option might be just using a board and bolting it down with about 8 inches overhang on each side. Then you can have lever on both sides to twist.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Black Tank-To Flange or not to Flange? Mrwaterway Waste Systems, Tanks & Totes 4 12-02-2009 09:02 AM
Need flange for my toilet-b/w tank 68Glbtrotter Waste Systems, Tanks & Totes 7 01-24-2006 08:07 PM
Toilet Flange won't unscrew!! mello mike Sinks, Showers & Toilets 11 07-11-2005 08:34 PM
HELP - Removing Toilet Flange Joe Z Sinks, Showers & Toilets 4 07-12-2004 10:10 PM
Toilet Flange Sneakinup Sinks, Showers & Toilets 16 06-30-2004 03:16 PM
