Old 03-03-2007, 08:35 PM   #1
1974 23' Safari
Phoenix , Arizona
Toilet / black tank removal '74
Hey All-
Have a 74 Safari, 23 foot that has a black tank leak. Went to remove the tank today and got the toilet out, sink out, hamper out and am stuck at getting the tank cover (shroud) off the tank. The manual says to remove the toilet flange by turning counter clockwise but the darn thing will not budge. I see there are two 1/4 inch depressions on the flange that looks like a special tool is needed to engage the flange and twist it off. Does anyone have any ideas?
I need to get the tank out tomorrow and am in a real bind. I thought about getting a piece of 1/4 inch square stock, cutting it to 4.25 inches and jamming it across the flange to see if I can turn it but I am open to other ideas.
Thanks.
Rusty9 is offline   Reply With Quote
Old 03-04-2007, 12:05 AM   #2
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Originally Posted by Rusty9
Hey All-
Thanks.
If the flange is like mine you can make a 'tool'. Cut some 1X2 stock a foot or two long then drill 2 1/4" holes the distance of the slots on the base of the flange. Into those holes place 1/4" bolts the length of the neck of your flange. You should now have a tool that will work as a spanner wrench. Hopefully the stock length will gve you enough leverage. If you don't believe it will cut the stock as long as you can for the space you have to work in. Also the flange should be screwed to your floor. Be sure those screws are removed. There may be debris filling the screw holes and is preventing you from seeing them.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 03-04-2007, 03:42 AM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
... I thought about getting a piece of 1/4 inch square stock, cutting it ...
Yes, that will work fine. This thread has a picture of one such home-made tool.
Tom
Old 03-04-2007, 06:03 PM   #4
1974 23' Safari
Phoenix , Arizona
Toilet flange
You guys are heros. I must have spent 2 hours yesterday trying to get the flange off. Went to a buddy's house today, fabricated the tool per the link, (thanks) and in 30 seconds had the part off and the tank out.
Now to fix the tank, which it turns out has 2 cracks in it, one on the lower wedge and one on the outlet flange, split almost in half. I think I might need to get a tank fabricated. I know of the company in Northern Cal that will make it to provided specs but the tank is marked El Monte Plastics and a google search shows them to still be in business in OH. Does anyone know if they can still provide tanks to factory specs? I have the tank PN off the tank.
Thanks again, you guys were real life savers.
Marv
cleaning up toilet tank release handle cindy Sinks, Showers & Toilets 0 10-19-2002 11:44 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
Replacing Black Water Tank Tamara Waste Systems, Tanks & Totes 15 06-18-2002 10:45 PM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 02:59 PM
