Old 01-10-2016, 09:54 PM   #1
1985 34' Excella
Durham , North Carolina
Toilet backing up, sewer outlet not clogged
We have 4 foot PVC pipe that we use as our plunger for our 85 Excella toilet. It's a Dometic toilet with a foot lever flush. I haven't been home to see it yet, but my wife says it backed up this afternoon, and the stick plunger didn't work. She also popped off the sewer port where it comes out of the airstream and it didn'tappear to be obstructed from there. Are there any recommendations aside from getting a Porta John service to come out and pump it?
bradleyoder is offline   Reply With Quote
Old 01-10-2016, 10:44 PM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Try this?
Name:	Arrowhead Ladle.jpg
Sirs Gawain & Galahad
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 01-11-2016, 07:08 AM   #3
1985 34' Excella
Sorry, but is this a joke? :-). Or is this a super long one that works from either toilet or outlet?
Old 01-11-2016, 07:43 AM   #4
Gainesville , Florida
It takes a brave person to open the sewer on a plugged toilet unless you are hooked to a sewer outlet. Try a plumbers helper.
Old 01-11-2016, 07:48 AM   #5
richw46's Avatar
Lexington , Kentucky
Our Dometic toilet is just a drop through the bottom into the tank, the step operates a flap in the bottom. How does yours back up, or is it just not emptying at the black valve? If you're hooked up to a sewer, did you leave the valve open all the time? That can cause solids to build up because it dries out, not enough water to keep things going. You may have a blocked discharge valve too. Is there enough room in the tank to try spraying down there with a garden hose to loosen things up?
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 01-11-2016, 04:40 PM   #6
1985 34' Excella
Opened the sewer hose and it's clear. Operated both main and auxiliary holding tank valves, though I had to work at it for a bit. I've let water run for more sufficient flushes for that reason, but there are five others in the house, so maybe piling up has cause some sticking. Thanks for this suggestion. We were starting to think that may be the next step... It's backing up below the flap, and then the flush water builds up above the flap. We have a pvc pipe we stick down in there to loosen up solids at the bottom of the pipe, but we don't feel any solids down there at the moment...I guess that means it may have built up at the outlet of the tank into the sewer outlet pipe?
Old 01-11-2016, 04:43 PM   #7
1985 34' Excella
Wait, what about a regular old plunger?
Old 01-11-2016, 05:26 PM   #8
1986 31' Sovereign
Miami , Florida
Get as much water down there as you can. With any luck, things will loosen up but it will be a while. There is a mountain of semi-solid material between the small portion of the tank you can see (and reach with your pvc pipe) and the outlet valve. If it is bad enough, you might even need to run a snake up there and try and loosen things up.
For future reference, black tank valve stays closed all the time until tank is full. Then dump it all at once. A nice bacteria/enzyme tank treatment helps as well. After dumping, start the tank off with a couple of gallons of water.
You can leave the grey tank valve open all the time but most of us will close it when we know we will be dumping the black tank in the near future to collect some "rinse water" for the stinky slinky.
Good luck,
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 01-12-2016, 06:08 AM   #9
Yes, a plumbers helper.
Old 01-12-2016, 09:11 AM   #10
1986 31' Sovereign
Miami , Florida
Don't know about a plumbers helper, lots of volume in that tank, don't know that a small displacement of air/water will budge anything but certainly worth a try.
Mike
Young, lovely bride
Old 01-12-2016, 10:34 AM   #11
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
A plunger from the toilet side will just move air (or perhaps air+water if it's REALLY full) in and out of the vent pipe, most likely. One would have to be super adventurous to use the plunger on the outlet side... it might be effective but MESSY. Things like the "Valterra Flush King" (a fitting for the outlet that lets you direct water into the sewer outlet from that end while the dump hose is attached) might help if the problem is an accumulation of solids blocking the valve.
— David
Old 01-12-2016, 11:49 AM   #12
I've used a plumbers helper in an AS and an Avion, it worked to some extent but not as good as in a regular toilet.
Old 01-12-2016, 01:44 PM   #13
1985 34' Excella
Tried plunger but it didn't work… Tried sticking a wire fish tape in through the outlet port to try to loosen it up from that end… that didn't work...heading to get a plumber snake, and some tank treatment. Good stuff at Lowe's, or do I need to shoot for RV specific stuff?
Old 01-12-2016, 02:29 PM   #14
Tuco's Avatar
1988 32' Excella
Ojai , California
This is what you need...
http://www.amazon.com/Valterra-F02-4.../dp/B008O9DV78
Works wonders...
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 260k+ (The Beast)
Tuco is offline   Reply With Quote
Sewer solution to home sewer-so difficult? lsbrodsky Plumbing - Systems & Fixtures 39 05-05-2018 09:35 PM
Sewer outlet 78 Safari cp1977 Waste Systems, Tanks & Totes 2 06-03-2015 04:04 PM
trouble hooking up waste water outlet to sewer hose Molly1973 Waste Systems, Tanks & Totes 9 05-21-2012 06:38 AM
Attention New to Airstream owners - sewer line outlet info - Thetford sewer systems Catman6 Waste Systems, Tanks & Totes 29 04-01-2011 05:22 PM
Staining Sewer vent from sewer gas TheProfessor Cleaning, Stripping & Polishing 6 02-16-2008 01:42 PM
