Old 01-12-2016, 03:22 PM   #15
1985 34' Excella
Durham , North Carolina
10-4
bradleyoder is offline   Reply With Quote
Old 01-12-2016, 03:22 PM   #16
1985 34' Excella
Better than a physical snake or rooter?
Old 01-12-2016, 03:37 PM   #17
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
What Tuco linked is the thing I referred to earlier, the "Flush King." It'll attack the clog from the outlet side, but with the dump hose attached so you avoid the opportunity for an icky mess. Then when you get the clog cleared it'll help you flush the tank and lines too.
David
Old 01-12-2016, 03:44 PM   #18
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Originally Posted by Tuco View Post
This is what you need...
http://www.amazon.com/Valterra-F02-4.../dp/B008O9DV78
Works wonders...
Does that just shoot water up into the tank with enough pressure to break up a blockage?
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 01-12-2016, 03:50 PM   #19
1986 31' Sovereign
Miami , Florida
Go real easy with a snake! That's either a poly or ABS tank up there and it is 30 years old -- you could poke a hole in it or damage the valve. So easy does it if you go that route.
Any ACE or True Value should have Rid-ex. (Don't know about the big box stores). There is one for septic tanks and one for RV's -- in this instance either should help.
I like the flush valve idea as noted above -- lots harder to break something...
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 01-12-2016, 03:59 PM   #20
1994 34' Limited
Round Rock , Texas
It sounds like this problem has been building up for a while. You may want to make some phone calls around town and see if there is a company that can come clean out your tanks using high pressure water. There are services for RVs specifically for this, and they use 1500psi water pressure vs. just standard water pressure from a hose (30-50psi). It may also fix issues like sensors not working, and any odors you may have.
Understand that you have to get a fix on this tonight so that you can use your toilet, but the cleaning sounds like it should be a high priority for you.
If you can't find the flush king locally, a Valterra Sewer Solution might be a good item to try as well. Same type of result, just a little different method.
Good luck, and start closing your black tank valve until the tank is full.
txtwin is offline   Reply With Quote
Old 01-12-2016, 04:20 PM   #21
Tuco's Avatar
1988 32' Excella
Ojai , California
It will shoot water into the tank with the valve open or back fill with the valve closed. In this case with the valve closed burp water into the tank to break the clog then drain. Once the system flows, back fill the tank for a minute or two then drain (valve closed). Repeat till the water flows clear and there are no chunks or paper. You can always use the milk shake maker to get a good clean (once the clog is gone). I use this on every flush to get as much of the solids out by shooting the water into the tank with the valve open. Let it run for a few minutes then shut the water flow off and let it drain. Rinse and repeat till the water runs out clear. Once a year I pull out the wand to clean the tank. This second method is a maintenance item and should be used once you are on top of the current problem. YMMV...
GL
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 260k+ (The Beast)
Tuco is offline   Reply With Quote
Old 01-12-2016, 04:38 PM   #22
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Warning
ARE you SURE that the tank gate hasn't pulled loose from the handle?
The gate is plastic and it is absolutely inevitable that it will eventually fatigue and break. You pull the handle in and out and nothing happens - and you cannot screw it back in. If the gate doesn't move, none of the treatments recommended above will work. If the handle goes in and out with zero resistance - you're screwed. If - WHEN this happens to my rig my very first step will be to call a pumping service and have the tank drained and rinsed repeatedly - through the toilet (or the hole in the floor after I pull the toilet up (and gag several times). If there's any room in the tank a quart of Lysol or Pinesol will go in there too. After that I'll tackle the replacement of the gate.
Let me go look for a good thread I remember on how to do this (gag) job. I pay for a lot of nasty repairs, but this is so nasty I don't think I could bring myself to ask someone else to do it. OTOH, paying the poor slob an extra $100 might just overcome my scruples.
HAH - found the thread in time to edit. Very good pictures of the repair process included: (NO sh** literally!) The man found a way to do the repair without pre-pumping the tank OR losing any "fluids" on the ground. A must read!
http://www.airforums.com/forums/f444...lve-84229.html
Paula
Old 01-12-2016, 06:49 PM   #23
1985 34' Excella
Does that flusher potentially send water up the vent stack/pipe?
Old 01-12-2016, 07:25 PM   #24
1986 31' Sovereign
Miami , Florida
Well, if you ran it for 50 plus gallons...
I think the idea is to cycle water in, yuck out...
Mike
Young, lovely bride
Old 01-12-2016, 08:43 PM   #25
1985 34' Excella
10-4. I just snaked from the outlet and we're back in business!! (Right after I order the flusher thing and a tank sprayer!).
So, we live in this thing, have hay bales shoved around the perimeter to limit wind and try and heat the crawl space with light bulbs so pipes don't freeze. I have giant ratchet straps holding the bales on, so each time I have to fiddle with the utilities, I have to partly dismantle all of that. Meaning, I really don't want to leave the gate closed until it's full and have to disassemble our insulation to open it...if we use plenty of water now, do I really need to let it fill and empty it?
Old 01-12-2016, 09:24 PM   #26
Tuco's Avatar
1988 32' Excella
Ojai , California
If you let the water drain then the solids will build up in the tank. Try and make the dump process easier to do. With your older trailer you will need an adapter to go from Thetford to Valterra.
Thetford to Valterra Adapter
We always keep a spare one of these. you will also need a Valterra slinky kit. Others here can let you know which type of slinky hose is best for cold weather. We found out the hard way that the Camco slinky's plastic shatters in sub zero weather (but I still like it).
Dave & MJ
Old 01-12-2016, 09:24 PM   #27
DKB_SATX's Avatar
1976 Argosy 28
If you don't learn from history you're doomed to repeat it.
If you can get one of those tank-cleanout wands and use it every couple of days you might put it off for a while, but it's a function of how these tanks are designed. They're supposed to have liquid retained in them for the solids to soften and break down and to have a big rush of liquid to carry it all away. Not that much water flows out of the flush valve fast enough to wash it all away every flush. Maybe modify the bale near the flush valve handles and have a chunk that's easy to remove/open (styrofoam or something, with a brick or two to keep it in place between dumps?)
With the flush-king thing you just ordered, you might be able to get all that set up with a water hose running out of the bales so you could at least flush the tank from that end without having to undo all the bales, just connect up that hose when you want to flush the tank perhaps?
David
Old 01-12-2016, 10:55 PM   #28
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You need to keep the black water dump valve closed until the tank is at least 3/4 full.
The sewer system in a house is totally different than in an RV. There is no holding tank. The household toilet has a trap built in. That's how the water stays in the bowl.
The RV toilet is nothing more than a very fancy outhouse. There is no piping between the toilet and the holding tank. Therefore nothing to plug in that area.
The solids in the tank are most likely your problem. If the dump valve operates correctly. Then the solids have built up enough to block the tank outlet.
If it were me I would call the "honey wagon" and have them pump the tank. It will take several cycles of them pumping then flushing then pumping again. Most holding tanks are not very deep which is a drawback in trying to pump them out.
It may be some trouble to remove the hay bales to dump periodically. But it most certainly will be easier than what you are going thru now.
By the way. IMHO Hay bales are a bad idea. They make great homes for rodents and are a fire hazard.
Sewer solution to home sewer-so difficult? lsbrodsky Plumbing - Systems & Fixtures 39 05-05-2018 09:35 PM
Sewer outlet 78 Safari cp1977 Waste Systems, Tanks & Totes 2 06-03-2015 04:04 PM
trouble hooking up waste water outlet to sewer hose Molly1973 Waste Systems, Tanks & Totes 9 05-21-2012 06:38 AM
Attention New to Airstream owners - sewer line outlet info - Thetford sewer systems Catman6 Waste Systems, Tanks & Totes 29 04-01-2011 05:22 PM
Staining Sewer vent from sewer gas TheProfessor Cleaning, Stripping & Polishing 6 02-16-2008 01:42 PM
