Old 12-24-2011, 03:47 PM   #1
NicheVintage's Avatar
1965 26' Overlander
The Gorgeous Pac Northwest , Washington
Images: 34
Time for a new Black Tank Where to start?
Well the time has finally come for us to replace our original black tank on the 65 O'lander. Is has sprung a leak... My question is where to begin. I know we need to drop the belly pan. Should we take off the entire belly pan or just cut and replace a portion? Also I should mention we have an original and functioning Swirl O Matic that we would like to keep. How will a new tank bolt up? Will this cause issues as far as a flange is concerned? Also what parts are involved other than the tank and flange on toilet? Is there a possibility of the original tank not working with a new tank? Sorry for all of the questions but I am trying to convince the hubby that we can do this and don't need to take it somewhere.
Also where is the best and most cost effective place to purchase said new tank?
Thanks for any help.
Happy Holidays.
WBCCI# 2578
Four Corners Unit
Our travel and resto blog:
http://web.me.com/tiffanydanley
NicheVintage is offline   Reply With Quote
Old 12-26-2011, 09:22 PM   #2
Elf1's Avatar
1990 34' Limited
Proud to be , an American
Your tank may need to be a special order.
IF...and I mean if you need to go that route, I may be able to assist you with a contact that will build the tank to spec. The turn around is 3 business5, bus days. Shipping is 50-70, however the tank will set you back- PM me if I can be of assistance.
Best
Rob aka Elf1
Elf1 is offline   Reply With Quote
Old 12-26-2011, 09:25 PM   #3
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Call Inland RV, they had a bunch of the early stuff reproduced if my memory serves me right. I know they had one for our 69 tradewind.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Black Water Flush Blocked ElliotA Plumbing - Systems & Fixtures 6 04-01-2017 06:26 PM
Black and Gray water holding tank leak GoodRed Road 1974 - 1979 Ambassador 0 09-19-2011 04:39 PM
Inspecting fuel pump and tank interior DaveFL Land Yacht/Legacy Motorhomes 2 08-19-2011 06:13 PM
Auxilary Fuel (gasoline) Tank? DGJackson 1970-79 Tradewind 3 08-18-2011 10:44 PM
mounting toilet flange on black tank 386kustoms Sinks, Showers & Toilets 3 03-04-2011 07:52 AM
