Two things...don't pull those levers untill after you hook up the hose~!!
btw, the second thing..? you don't have to worry abt if you get the first thing right...
NOT A DUMB Question~! except if you don't ask..
__________________ WBCCI 5292 AIR 807 NEU #64 New England Unit
Good question!!! Seriously, there are NO dumb questions.... here, or anywhere.
If this is a 'new to you' new AS, then be sure to do a couple of things that will help you immesurably. When you get the trailer, get a thorough walk thru from the PO - or as best they can do. Then ASAP find a 7-11 (or similar) and buy at least 10 lbs of ice cubes (20 is better) and then dump them into the BT via the toilet.... Then go for a scenic drive, or haul her home. Let that ice slide around and scour the BT and any/ all leftovers that are still there.... When you get home the tank will be clean and have something worth dumping.....
Then follow the dump instructions (use a CG for this - you'll see why in a minute) you have gotten above. After the 1st dump, find a way (Flush King is GREAT!!!!!! about $35 or so at CW) to re-fill the tank with water. Dump again. Be sure that the water coming out is as clean as it was going in..... If it isn't - re-fill, repeat the dump, etc.... til it is CLEAN water coming out via the hose.... This is the beauty of the CG, all the water and dump facilities right there!
Doing this will make ALL other aspects of your new trailer all the better. BT clean is imperative! Believe me on this one!
All the best! and keep posting all your questions.
Now you have ruined it! I was hoping you would tell him to rent it and follow it exactly.
Seriously, No dumb questions, just dumb answers.
The ice cubes is good for cleanign the tank and a flush king is good for making sure it is clean. Hope you don't mind looking at your own poo. Have to, to see if the tank is properly rinsed.
Flush black first then grey. The grey will "rinse" out the sewer hose.
I have a grey tank, but do this anyway to ensure everything is gone from the black tank after I dump it.
I fill a 6 gallon water jug at the dump station and take it into the bath room. After the tank has drained I have my wife close the valve and I start to dump fresh water down the toilet. When the jug is half empty (or is it half full) I tell her to pull the valve and I continue to pour untill the jug is empty. I then do a visual check to make sure nothing has been left behind. This should clean out the hose as well.
After I finish with the black, I drain the grey, close the valve, disconnect the line, install the drain cap and rinse the line out with a hose. I stow the hose and remove my disposable gloves.
Not my favorite part of the trip, but it sure beats all the years we camped in a popup with out any bathroom.
Thanks for all the info guys! This is a "new to me" trailer and I just wanted to be sure I had all the bases covered before I head out in it. The PO did a basic walk-through with me, but the trailer had been winterized so we did not cover any of the dumping issues. Seems pretty straightforward. I have not put anything other than clear water in either of my holding tanks as of yet since we have it parked in my drive way and I did not need any surprises if there was a leak. No leaks so far! Next time we move it, I will try the ice in the tank thing and fill the tanks and dump before we use it.
Thanks again all!
I do what azflycaster said...except, I have no grey tank...so I fill the kitchen sink w/ hot soapy water. I figure that the energy used to heat that water is just gonna get wasted, anyway...might as well use it to clean out my slinky.
so after I'm done w/ the black, and the bucket-fresh water rinse, I let go of the kitchen sink. then a thorough hose rinsing, and we're done.
Glad to hear that the unit seems to have had an attentive PO.... Can only bode well....
Still.
Consider, seriously! Getting that FlushKing, or similar. FK allows a hose (non-drinking) to be connected to refill the BT thru the fitting that also does the dumping as well.... has a section of clear tubing that allows you to "SEE', and have 'clarity' of all things in - AND OUT!!!! KEEP flushing (repeat! as needed) until it is all CLEAR!!! Seriously. Then +1, in my experience....
This is the KEY! it is CLEAR!, In and OUT.
My PO was extremely thoughtfull and really ran a well organized unit.... and still I found BT 'items' that shouldn't have been there with a COMPLETELY clean unit....
Again, not to be too "anal", but well, there is NO such thing as TOO careful when it comes to a clean BT....!
FlushKing is a terrific way to solve a issues related to BT flushing (repeat, with results!) - use the "Ice Cubes" as an additional 'curative' and all things BT and related will go WAY DOWN your list of things to do and consider.... not to mention, it'll smell better too.
Sorry if I seem to be harping on this one issue, but it really can be the difference between a unit you LOVE and one that you tolerate or hate.... That would be a waste of a perfectly good AirStream, in my opinion.
Get a FlushKing (or equivalent) and be done with this issue.
Be sure to ask any and all quesions - we'll be glad to help!
Couldn't 'xactly say - "Oh Brother Where Art Thou?"
No info on the other choice you mentioned, but I CAN vouch for the Flush King... check out their Web Site... you can get them at Camping World and perhaps your local RV favorite store..... Easy, works as advertised. All good in my book.
