Old 07-09-2007, 12:19 PM   #15
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Good question. They function simularly. Buy one and let us know!
Michelle TAC MT-0
Sarah, Snowball
Old 07-09-2007, 12:44 PM   #16
1974 25' Tradewind
Muscle Shoals , Alabama
I just noticed that it was considerably cheaper. I'm always afraid of the old adage "you get what you pay for", however. I guess we'll see.
chuman70 is offline   Reply With Quote
Old 07-09-2007, 01:21 PM   #17
Mrs_RedSHED's Avatar
2014 16' Sport
Columbus , Indiana
Originally Posted by SilverToy
This is the KEY! it is CLEAR!, In and OUT.
y
Okay, Okay. But why CLEAR? Other than gook-free sensors, what do you gain by getting your black tank CLEAR? We do not get that rigid about the black tanks condition and have never had an odor problem or other tank problem. We do run a couple of toilet bowl fills down the drain to the BT (with some formadehyde-free chemical), after dumping. Does it just make you feel better about the blank tank and it's former contents? Just because the water is clear, it is not germ-free.
I can see the sense in the 20 lb bag of ice cubes method, occasionally to scrub off those sensors, but why CLEAR every time?
Mrs_RedSHED is offline   Reply With Quote
Old 07-09-2007, 04:23 PM   #18
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Originally Posted by anholman
What if you don't have a grey tank?
Neil.
We fill the tub...just to be sure & get the hose "squeaky clean" when we are through.
Shari
Old 07-10-2007, 07:11 PM   #19
Keymar , Maryland
Not always. Sometimes one maybe better than the other sometimes just more expensive just because it is the name to own.
Michelle TAC MT-0
Sarah, Snowball
Old 07-10-2007, 07:37 PM   #20
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Don't forget the chems. Most, if not all, campgrounds have gone to banning the formaldehyde based chemicals these days. We have tried the orange granules and the "green" natural granules. I like the orange ones better because the green ones smell like pine oil and I prefer the orange smell of the orange ones...yes, I can smell them both when the flush door opens.
I get them in the pre-measured pouches and put one in every day and dump the tank about every third day. After the final dump, I flush with our built-in tank flusher. I run it about 2 minutes with the valve closed and open to empty and then repeat twice. I close the valve a final time to put about 3-4 gallons of water in the black tank and add one of the orange pouches through the toilet and disconnect everything for the ride home. At home I put one of the pouches in the black tank every week between trips. So far this seems to keep the odors down and all the waste products "digested" by the enzymes in the orange pouches.
Family of Disney Fanatics
WBCCI# 4821
Old 07-10-2007, 09:35 PM   #21
mandolindave's Avatar
I don't go nuts cleaning the black tank for every trip
But I use it almost every weekend in the spring and summer, and use an enzyme system that actually calls for some fecal matter to feed and in turn "grow" the enzymes. No formaldihydes ( excuse the spelling ).
I clean the slinky with a hose.
mandolindave is offline   Reply With Quote
Old 07-10-2007, 09:40 PM   #22
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I like the idea of the Camco Dual Flush or Flush King. Now without a grey tank what if any is the problem of backing BT contents up into the grey sewer and my nearby shower? Also with the vintage placement of the dump (center rear) drain exiting into the rear bumper storage area. I see maybe some metal cutting and fashioning a new bottom access drain door so as to provide the space needed for the flushers. I can do that to get the convenience of these flush products but I would like to hear if anyone has done this with their rear bath vintage coach.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 07-11-2007, 05:49 AM   #23
Images: 59
A macerator pump with a built in tank sprayer is a good alternative for a rear bath vintage coach. Then you can get rid of the slinky hose altogether.
Old 07-11-2007, 07:44 AM   #24
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
yes, but not unless you have a seperate grey tank...or, at least, valves that block off the gray lines. If you have an "on the floor" black tank, it will fill the shower with its contents if there is even the *slightest* restriction in flow when you open the black tank valve. ask me how I know.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 07-11-2007, 07:55 AM   #25
2006 30' Safari
Orlando , Florida
Now without a grey tank what if any is the problem of backing BT contents up into the grey sewer and my nearby shower? ...
Neil.
If you mean while showering and the contents of the black tank back up into the shower on units without gray tanks, you wind up standing in a open sewer ankle deep in fecal matter/urine. !!!!!!!!!!!
If you mean while dumping and flushing the tank, you need to disinfect the shower pan and possible the floor of the bathroom.
WBCCI# 4821
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
My dumb question about holding tanks JaceBeck Our Community 6 12-07-2002 01:22 AM
Dumb question - 345LE - does the gennie charge the auto battery? williamhenshall General Motorhome Topics 6 08-26-2002 05:49 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
