Old 12-08-2013, 09:21 PM   #1
jrb3000's Avatar
1973 23' Safari
Woodstock , New York
Thinking about trying to repair my black tank's flange adaptor
My renovation is just getting started and already I have had a few surprises. I'm considering trying to fix my black tank. It looks like the input hole just broke off at some point. Whoever "fixed" it had the toilet just pointing into the hole you see in the top of the tank... no seal whatsoever... gross.
I'm considering cutting a round hole in one of these: Plastic Sheets | MSCDirect.com
Then attaching the receiver for the flange.
Then I'm thinking I can weld it to the original tank so the flange receiver is in the right spot and so I seal the tank. It seems like it's worth a shot for $20 vs. buying a new tank.
Anyone else tried this?
Name:	Photo Nov 30, 3 33 50 PM.jpg
jrb3000 is offline   Reply With Quote
Old 12-09-2013, 04:42 AM   #2
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
I think the cost of a new black tank is money well spent, considering the amount of work it is to access, remove and install.
Lance
Top is offline   Reply With Quote
Old 12-09-2013, 07:30 AM   #3
65CV's Avatar
Western , Massachusetts
Looks like the same blue plastic as my first Fresh Water Tank. I tried to reuse it and it cracked on the first trip. I am so thankful it wasn't the black tank that cracked!
65CV is offline   Reply With Quote
Old 12-09-2013, 07:48 AM   #4
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
I agree with the rest. I'm making my own black tanks. It's just not something you want to do twice. You're already there, spend the money and do this part right. Anything else you could probably skimp on, but not the tank. Check Vintage Trailer supply. Your other option is to go with something smaller, but that will still fit in the space. I'd rather have a smaller tank, than a tank I have to worry about.
robwok is offline   Reply With Quote
Old 12-09-2013, 08:35 AM   #5
jrb3000's Avatar
1973 23' Safari
Yeah you guys are all probably right... not the place to try to save a buck.
