Old 12-08-2006, 10:42 AM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Things to have to make sewer issues easy
Just wondering how a long the two hoses I buy should be?
One for potable. and the other for Sewer Solution hookup.
Not having done this before, didn't know what lenghts to buy.
'77 Sovereign Intl 31' CB
Old 12-08-2006, 10:48 AM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
I find that it's pretty variable, and depends somewhat on how and where you will camp.
I have a 20' sewer connection hose. It's longer than I need in most cases, but it's almost always long enough.
Fresh water hose (white) I think is 25' but depending on where I'm camping, I may throw an extra hose in the TV just in case.
And then a seperate hose (mine is green, normal garden hose) for rinsing out the slinky hose, etc.
Dave
Fyrzowt is offline   Reply With Quote
Old 12-08-2006, 10:51 AM   #3
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
We also have a 20'. The only time we had difficulty reaching was up at Moorefield campground at Mesa Verde: They lengthened a site by adding space at the back, but that move left the water and sewer stranded far to the front of the site. Fine for other RVs, where connections are often located further toward the front, but not ok for the 67, where everything is way in the back.
Lynn
WBCCI 21043
Old 12-08-2006, 11:02 AM   #4
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Also consider going with the better grade sewer hose material. Once you stretch out a hose you stand a better chance of it being damaged by ground debris. I always felt that the extra $$ spent on heavy duty hoses were paid back in longevity and peace of mind when I pull out that black tank handle.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 12-08-2006, 11:06 AM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
If you have seen the movie "RV" you will understand why the proper sewer equiptment is a must!
Richard
Old 12-08-2006, 11:12 AM   #6
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Originally Posted by jcanavera
Also consider going with the better grade sewer hose material. Once you stretch out a hose you stand a better chance of it being damaged by ground debris. I always felt that the extra $$ spent on heavy duty hoses were paid back in longevity and peace of mind when I pull out that black tank handle. Jack
Yes, and you don't need to see "RV" to understand, either! Late last June we had a big hail storm here. There were punctured sewer hoses all over the park. Pretty putrid. I used a good deal of chlorine on the grass afterwards.
Lynn
WBCCI 21043
Old 12-08-2006, 11:21 AM   #7
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
We have found after our 6K trip this year that it is always better to have than have not! We carry 2 -25' white fresh water hoses, one 25' green everything else hose and we have three sewer hoses all with assorted couplers. This way was can make those long stretches, the short ones and the medium ones with out too much sewer hose everywhere.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 12-08-2006, 11:52 AM   #8
A good combo for water hoses, is a 25 foot and a 50 foot.
That gives you 25, 50 or 75 feet.
Same way with sewer hoses.
Carry a 10 foot and a 20 foot.
That gives you 10, 20 or 30 feet.
Old 12-08-2006, 12:14 PM   #9
Dwight's Avatar
1999 34' Excella
Joshua , Texas
We carry 6 joints of the Sewer Solution hose, yes that sounds like a lot, but we have been at a few RV parks that had the sewer tap at the opposite end of the site than the water and electric hookups.
Dwight is offline   Reply With Quote
Old 12-08-2006, 02:41 PM   #10
Fyrzowt's Avatar
2000 25' Safari
Images: 8
I sometimes wonder what some of these park designers were thinking...of IF they were thinking. Most are OK, but every once in a while...
Dave
Old 12-08-2006, 03:23 PM   #11
_
hi lipets
didn't you start a sewer connector thread last month?
http://www.airforums.com/forum...et-26507.html?
or do you NOW ask about water hoses used for various needs like drinking and tank flushing?
-a set of hoses for fresh water depending on distance from the source..10s, 25s and 50s usually and in combinations...
-a grey tank/black tank flushing hose (usually black or gray colored but garden hose works too)...again how far do you expect to be from the water source...usually 20 feet is plenty for flush hoses...
a garden hose for washing tv or trailer? i carry these 2...
y connectors for the water tape and various adapters like a water thief...which i've not had to use in 2 years or the last 450days of camping.
like the tank flush process it self...
it helps to keep the info all linked together
hoses or threads...
there are many threads here on the sewer solution or flush king or other methods intended to improve the basics....search and read,
but first just do some dumping the basic way....
learn your camping habits and needs as experience accumulates...most do fine with only the basic bits and pieces.
and save money for fuel and beer!
cheers
2air'
A tale of woe - how I saved a buck on tires and destroyed my sewer connection dmreilly10000 Tires 30 04-10-2006 12:22 PM
HELP PART NEEDED! Aluminum Termination Cap... InsideOut Waste Systems, Tanks & Totes 46 03-20-2006 06:08 AM
Have you ever done this?? thenewkid64 Our Community 18 10-12-2002 02:29 PM
Fixing things-'RV Repair and Maintenance Manual Joan D'Andrea Our Community 6 09-19-2002 04:49 PM
Blinds ALANSD Upholstery, Blinds, Walls & Interior Finishes 35 04-01-2002 01:54 AM
