Old 06-21-2007, 06:28 AM   #1
1976 24' Argosy 24
Milford , New Jersey
Thetford Valves, Repair or replace?
Hello all. 76 Argosy 24' rear bath. Well i dropped the rear of the belly pan to find a shower leak, and discovered that the P- trap had cracked. So I think i found my leak. But I also noticed that i have a hanging drop of water on the outside of my graywater valve. No drip per say, just wet. Thought I should address this while she's opened up. Any thoughts on rebuilding the old valves vs replacing them? The hard part about replacing them seems to be that the factory glued the valve to the 4" outlet pipe! So replacement will mean making all new 4" outlets. Has anyone had good luck rebuilding the valves?Thanks, George.
Gkiesel is offline   Reply With Quote
Old 06-21-2007, 06:39 AM   #2
Old Paint, rolling again.
sfixx's Avatar
1973 Argosy 20
Lorain County , Ohio
Images: 12
You may poke your nose into the idea of cleaning the valve first. Perhaps it's gummed up and will not close completely. Some have had success by fabricating a scratch tool to scrape out the valve guide slots. A forums search will produce better advice...
Good luck,
Stephen
Have you never questioned those who travel? Have you paid no regard to their accounts- Job 21:29
sfixx is offline   Reply With Quote
Old 06-21-2007, 08:40 AM   #3
George, yes, as described here, using the repair kit is straightforward:
http://www.airforums.com/forums/f444...ves-28812.html
If the internal surface of the valve is scratched, complete renewal of the valve would be preferable, IMHO. With plenty of time, I would opt for complete replacement. However, my Airstream manual states that the Airstream factory just uses repair kits.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 06-21-2007, 11:41 AM   #4
1976 24' Argosy 24
Thank you Nick. Rebuild it I say!
Thetford Toilet Repair??? Galaxy Low Profile ViewRVs Sinks, Showers & Toilets 11 05-03-2010 03:27 PM
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
gas valves gmlcjb LP Gas, Piping, Tanks & Regulators 5 07-17-2006 09:31 AM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 04:01 AM
