Old 10-08-2011, 10:25 AM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Thetford valves hard to open/close
I rebuilt both of them 5 years ago they were always tight as to open close.
when closed they don't leak.
Was think about throwing something in the tanks to lubricate is that possible?
If so what to use?
'77 Sovereign Intl 31' CB
Old 10-08-2011, 10:35 AM   #2
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Try adding a lot of olive oil to your diet...
tphan is offline   Reply With Quote
Old 10-08-2011, 10:40 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
While the valves is open, while dumping, try rubbing paraffin wax on the shaft and work it in with additional applications.
2004 Excursion 4x4
Old 10-08-2011, 11:00 AM   #4
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I once had a problem with the valve on the Caravel and found it to be a little rust on the shaft, not a problem with the gate itself.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 10-08-2011, 11:04 AM   #5
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Shaft looks clean, I'll try the paraffin and oil.
Howie why paraffin, instead of perhaps silicone spray
Old 10-08-2011, 11:21 AM   #6
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Anyone ever pour some olive oil or vegetable oil in the tank an then drain?
Phrunes is offline   Reply With Quote
Old 10-08-2011, 06:04 PM   #7
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Not sure that is a good idea????
What about unwanted growth if left unused?
Dave
Old 10-08-2011, 06:30 PM   #8
HowieE's Avatar
Images: 12
Just and old carry over from my working days. Paraffin dose not collect dirt and will not flow to unwanted areas. Oil and grease end up everywhere.
2004 Excursion 4x4
Thetford waste valve replacement Safari64 Plumbing - Systems & Fixtures 6 02-24-2012 08:32 PM
Thetford Style II toilet model 42059/replacing Lothlorian Sinks, Showers & Toilets 4 08-23-2011 05:07 PM
Thetford Aqua Magic Style Plus? davidz71 Sinks, Showers & Toilets 2 07-03-2011 10:11 PM
Convert or Replace Thetford Waste Valves Emh142 Waste Systems, Tanks & Totes 2 05-15-2011 07:05 PM
Water Hose - Hard Water Deposits Al - K4GLU Fresh Water Systems 4 02-16-2011 04:00 PM
