Old 06-14-2007, 09:21 AM   #1
1976 27' Overlander
Hackett , Arkansas
Thetford Valves?
I need to replace the dump valves on my 1976 Airstream while replacing the balck water holding tank. The originals are Thetford; however, I am thinking about going back with a different type. Is this advisable? Is there a better alternative?
Also, someone suggested that I install electric valves that can be operated from the inside. Has anyone had any experience with those?
sugarloafin' is offline   Reply With Quote
Old 06-14-2007, 09:47 AM   #2
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
My experience has been the Thetford valves last a very long time. Valterra valves seem to get sticky and difficult to operate after a short time - just my own experience. Notice the price difference between the two.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 06-14-2007, 10:41 AM   #3
dnrtheil's Avatar
1964 24' Tradewind
Portage , Michigan
I was going to replace my old Thetford valve with a Valterra but they are not the same size. Overall the Valterra was smaller and the mounting holes did not line up.
dnrtheil is offline   Reply With Quote
Old 06-14-2007, 04:03 PM   #4
My experience is that the Thetford valves are a quality product that will often last 20 years or more. Bearing in mind the unpleasant labor involved in changing them when defective, you are right to want the best, and I know of none better than the Thetford.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 06-14-2007, 04:28 PM   #5
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Unless the dump valves are VERY easy of access, I wouldn't opt for electric.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-15-2007, 10:01 AM   #6
1976 27' Overlander
Hackett , Arkansas
How different are the valves. I am having difficulty locating a valve with the specific model number as my originals. Does it matter? Is there not just a 3" hole on each side and a valve in the middle?
Old 06-15-2007, 10:07 AM   #7
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
I'm not sure that I see the benefit vs cost of electric unless there are physical limitations. You still have to go back there to unhook the slinky, you may as well pull the handles while you're there.
Dave
Fyrzowt is offline   Reply With Quote
Old 06-15-2007, 10:23 AM   #8
Originally Posted by sugarloafin'
How different are the valves?
Some are "bond-on", some are "clamp-on", some have the T-handle on the valve, others have a threaded end for your long handle. You will find pictures here:
DyersOnline.com - RV Supplies, Parts, and Accessories - Valves
To be sure, you can phone Dyers-online at toll free 1-866-713-3429.
Nick.
Thetford Toilet Repair??? Galaxy Low Profile ViewRVs Sinks, Showers & Toilets 11 05-03-2010 03:27 PM
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
gas valves gmlcjb LP Gas, Piping, Tanks & Regulators 5 07-17-2006 09:31 AM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 04:01 AM
Waste Water Outlet Valves Danno Waste Systems, Tanks & Totes 2 06-18-2002 10:48 AM
