Old 03-28-2009, 02:13 PM   #1
1982 28' Airstream 280
Buena Park , California
Thetford Valve Repair
My waste tank was slowly leaking and I didn't know the cause but since I was out in the desert, I thought I would take care of it when I dumped. When I dumped, I thought succesfully, the moniter said I was still 1/4 full. And I was. I was clogged with poo and nothing more would dump. So I spent some very smelly time getting through that clog. I took the valves off and opened them up. The grey water valve seems to have no problems. The black water valve however....
The plastic gate that comes down to shut off the flow gets caught on the rubber seal and did not close all the way.
So I think my problem was the water slowly leaked out leaving behind a solid mass of poo, hence my clog.
I cant seem to find any repair kits for the thetford that is just seals. I dont think I need a whole new valve, but since I am with out seals, I think i will need to buy a new valve afterall.
Any ideas about the seal issue?
and if I have to buy a new valve, should I get a thetford or valterra.
Thanks a lot.
kennytheecat is offline   Reply With Quote
Old 03-28-2009, 02:53 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi Kennytheecat, First off . OK, I don't know the year of your trailer but, I think this thread will help you. Click here. Good luck!
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 03-28-2009, 02:55 PM   #3
sweet! a repair kit! thanks.
I have an 1982 28' airstream motorhome
Thetford Valve Installation Tom Bray Waste Systems, Tanks & Totes 8 09-07-2008 08:57 AM
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Thetford Slide-Ez toilet valve repair bwjohnson Sinks, Showers & Toilets 6 10-28-2006 08:44 PM
Only one Thetford Valve? The Flintstones Waste Systems, Tanks & Totes 10 10-09-2006 08:53 PM
Thetford Valve garyphelps Sinks, Showers & Toilets 1 08-27-2006 07:54 PM
