Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 11-04-2009, 11:06 AM   #1
Profile:  1977 27' Overlander
Beatty , Nevada
Thetford Valve Connection to waste piping
77 Overlander.
Tried to pull black water outlet off the pipe last weekend per the service manual which indicates that SOME valve to pipe connections that year may be glued. Would appear that mine is one of those.
I have a spare valve which was left in trailer by PO. Appears to right valve but also appears to missing O rings. W/O O rings outlet side of valve does not fit well in to a new 3" long sweep T-Y so am wondering how they glued valve to pipe? Would rather not glue up replacement so w/ O ring do pipe and valve seal correctly?
Also anyone know where to get O rings or best to just buy a whole new valve from Inland RV or anyone else?
TIA,
77Overlander is offline   Reply With Quote
Old 11-04-2009, 11:50 AM   #2
kennethowens's Avatar
Profile:  1975 Argosy 24
Malakoff , Texas
Go to a Plumbing supply business...not Lowe's or Home Depo.
The person at the counter will know what you are doing. A digital
camera with a few pic's of the trailer end will help when you go.
kennethowens is offline   Reply With Quote
Old 11-04-2009, 09:27 PM   #3
Sugarfoot's Avatar
Profile:  1960 24' Tradewind
1956 30' Sovereign of the Road
Southeastern Area , Tennessee
If you can't find anything locally, try McMaster-Carr. I know others have found O-rings that worked with even older Thetford valves there.
TRAVELING WITH ELVIS
LIFE WITH A 1956 SOVEREIGN OF THE ROAD
• • • Aluminocentricity • • •
WBCCI# 14674, Washington DC Unit
Sugarfoot is offline   Reply With Quote
Waste valve Apache_Camp All Argosy Trailers 10 10-05-2009 08:06 AM
Valterra to Thetford connection Craig Waste Systems, Tanks & Totes 28 09-10-2008 07:07 AM
waste valve 1963tradewin 1959-69 Tradewind 8 05-23-2008 08:27 AM
Only one Thetford Valve? The Flintstones Waste Systems, Tanks & Totes 10 10-09-2006 09:53 PM
Thetford Valve garyphelps Sinks, Showers & Toilets 1 08-27-2006 08:54 PM
