Old 05-31-2015, 01:34 PM   #1
1995 21' Sovereign
Castle Rock , Colorado
Thetford Toilet removal, 1994 Sovereign 21'
Recently purchased Sovereign 94, 21' with at Thetford , Aqua-Majic.
I need to take it out and put in a New Thetford.
I see NO bolts to remove. Sides are Flush all the way down to the carpet, no indents. Toilet is sitting on top of a box with carpet / factory. Do I twist it? Just rip it up?
The new one shows 2 bolt holes in the standard position for a Toilet.
I hope someone has removed one like this.
tjansen is offline   Reply With Quote
Old 05-31-2015, 02:30 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
One bolt should be accessible from the back, an arm breaker. You should see a 1 in. plastic plug along the front under the seat for the second bolt. You will need an socket extension to get that one.
The newer toilets are a bit easier. If you have a rug on the bathroom floor it will be impossible to mount the front access cover unless you cut some off the bottom of it. No big deal no one gets down there to look anyway.
2004 Excursion 4x4
Old 09-20-2017, 04:59 PM   #3
1990 25' Excella
Wylie , Texas
Do you still have the toilet. I am in need of one you can email me at brown9726@hotmail.com
Gopher831 is offline   Reply With Quote
Old 09-20-2017, 06:18 PM   #4
1994 30' Excella
Mississauga , Ontario
The rear bolt on the left hand side when looking from the front is accessible from the rear. Not easy. As mentioned under the seat there is a plug that can be removed. In my case it would have taken about a 16 inch socket extension to reach the nut. I groped for is from the rear.
The other bolt is accessible by depressing the flush pedal and reaching through the gap.
I wish those that design these things had to install or remove one.
Al
Al and Jean
TAC ON-3
sovereign
Replace Thetford with Thetford or Valterra? evansm1974 Waste Systems, Tanks & Totes 1 10-06-2014 09:01 PM
bake315's 1994 34' Limited :: 1994 Airstream Classic Limited bake315 Airstream Registry Discussions 1 08-31-2011 03:01 PM
Thetford Toilet Repair??? Galaxy Low Profile ViewRVs Sinks, Showers & Toilets 11 05-03-2010 03:27 PM
Thetford Galaxy removal gparker Sinks, Showers & Toilets 4 11-02-2006 04:03 PM
Replacement Toilet for Thetford Aqua Magic? JeepinAudiophile Sinks, Showers & Toilets 1 09-20-2004 11:05 AM
