Old 07-01-2007, 05:46 PM   #1
2016 30' Classic
2009 25' FB Flying Cloud
Dade City , Florida
Thetford PN 01447 Replacement
We have a 1969 GT with a leaky black tank valve. I have attached pics and would appreciate any suggestions on where I can purchase a replacement or a repair kit. Also, could someone outline the steps I need to take to replace? Do I need to cut the existing piping to remove the old valve? What is the right way to do this? Thank you for any help with this,
DaveClick image for larger version
dbaur is offline   Reply With Quote
Old 07-01-2007, 08:42 PM   #2
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Have you tried searching?
To bump this up, I wonder if you've used the search tab above to key in words like thetford and sewer and black tank valve replace to find previous threads and messages. I know others have faced same problems...
Several interim suggestions..
1. Sometimes leak is caused by blockage in groove that valve plate slides into... A bent object like tine of fork can sometimes dislodge paper or material in the groove and cure leak..
2. Thetford still makes compatible parts for many of their fittings (one of reasons Airstream used them so long) you might try Airstream or thetford dealer to see what they can find available.. (Not all dealers will be as diligent in searching, so be persistent...)
John
Condoluminum
Condoluminum is offline   Reply With Quote
Old 07-01-2007, 09:24 PM   #3
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
There is a seal kit that you can buy to renew the seal in the valve. No cutting required. It will require removing the screws that hold the valve together and replacing the o-rings, etc. They sell a refurb kit for this valvle for less than 20 bucks. Need to order it from camping world, they normally don't stock it.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 07-02-2007, 04:07 AM   #4
2016 30' Classic
Dade City , Florida
I'll follow up on both suggestions. Thank you.
Old 07-02-2007, 08:03 AM   #5
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I've ordered parts directly from thetford.
Thetford Corporation
Customer Service Department
1-800-543-1219
Thetford and Norcold Domestic Facilities
Corporate Headquarters, Administrative and Marketing Offices
Street Address
7101 Jackson Road
Ann Arbor, MI 48103
Phone: 1-800-543-1219
734-769-6000
Fax: 734-769-2023
crispyboy is offline   Reply With Quote
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Toilet Replacement 3Ms75Argosy Sinks, Showers & Toilets 22 02-18-2007 07:51 PM
Water inlet key replacement Road Ruler Fresh Water Systems 7 09-03-2002 09:07 PM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
