Old 01-08-2006, 04:40 PM   #1
GTracer's Avatar
Images: 16
Thetford EZ Slide T-1169 Dump valve Leaking ???
I have discovered that my dump valve is leaking and my collector is cracked and leaking. I'm seeing that buying this replacement part is probally not going to happen. Would anyone know of a matching dump valve that would fit my existing tank?
GTracer is offline   Reply With Quote
Old 01-09-2006, 07:19 PM   #2
steelbird312's Avatar
1956 22' Safari
2000 39' Land Yacht XL Diesel w/slide
Crossville , Tennessee
Images: 11
Surely someone knows where to buy stuff to fit a 1970 Overlander.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 01-09-2006, 09:47 PM   #3
Over59's Avatar
Putnam , Connecticut
Images: 37
Call the company. They had a rebuild kit for my 68 at a very reasonable price.
Over59 is offline   Reply With Quote
Old 01-09-2006, 10:11 PM   #4
Creampuff
Creampuff's Avatar
1957 22' Flying Cloud
1971 31' Sovereign
1976 29' Ambassador
Malibu , California
Images: 60
Go Valterra whenever possible
If you have problems beyond your dump valve, i.e. cracked plumbing, you are better to consider a retrofit to VALTERRA parts. These are now industry standard and easy to get. There is a adapter that bolts to your tank (4 bolt) and then you can re-plumb with Valterra .This requires at least 1.5" additional space. You have not specified what year/model you own . Some of them are really tightly located and you have to cut a vent line to get them out. Usually though a Thetford replacement or kit can be found- it's just not possible to find the downstream plastic fitting that your sewer hose connects to.
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Fixed that dump valve !!! 77caravaner Waste Systems, Tanks & Totes 1 05-21-2010 05:55 PM
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Dump Valve Rebuild wagsrp Waste Systems, Tanks & Totes 2 10-12-2002 01:01 PM
Sticking Dump Valve 74SovereignInt. Waste Systems, Tanks & Totes 12 10-05-2002 06:14 PM
black-water dump valve... Chuck Waste Systems, Tanks & Totes 11 09-01-2002 08:22 PM
