Old 04-06-2009, 01:42 PM   #1
1967-Caravel's Avatar
1967 17' Caravel
East Bernard , Texas
Thetford Collector (original 67' Caravel)
Well I got the original dump valve off this weekend and all is planned to replace but I've run into another situation....................on the original "thetford collector" T fitting, it's the original one and someone before me cut off a portion of the bottom where the drain cap would go and theres just a cut pipe. Therefore I have no ears etc. to attach the bayonet drain cap. Figured this was easy enough just go to RV store and get and extension, etc. Well I went to RV store today and nothing fits. Obviously what todays 3" fittings and pipe are different diameters than the old stuff. Any solutions how to fix this so I can put a drain cap. I think I can make something work if I have to but wondering if anyone else ran into this problem.
Thx, Steven
Steven
"he who dies with the most toys wins"
1967-Caravel is offline   Reply With Quote
Old 04-06-2009, 04:14 PM   #2
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Thx, Steven
Hi Steven, I did run into the "Thetford nothing fitting" problem when I did my restore. I switched to Valterra. That way I can find fittings almost anyplace.
Is this what you are looking for ?
Name:	DSCN3140 (Medium).JPG
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 04-06-2009, 04:40 PM   #3
Thx, Steven
We routinely repair the collectors, even sometimes when pieces are missing.
We also have a aftermarket replacement.
Old 04-06-2009, 08:53 PM   #4
1967 17' Caravel
Yep thats the exact piece I'm talking about.......... The previous owner cut it off just above the drain cap ears leaving about 3/4" of just straight pipe below that square flange. Although not original I think I've come up with a $4 fix without having to spend money for the new collector, etc. I went ahead on my way home and bought the $4, 3" pipe fitting that has the drain cap ears at the local RV shop. It's a little oversize so it will fit around and over the cut pipe and sit flush on the square flange and my friend owns a body shop and I'm gonna have him fiberglass it to the square flange. Although not origianal it's a easy fix for me and I know it will work fine just for a drain cap. I also bought the $4 rubber 2" pipe coupler at Lowe's to reattach my gray water line I had to cut to remove valve and collector assembly
Steven
Old 04-06-2009, 10:50 PM   #5
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
That sounds like a good fix to me.
FYI - I do not need this piece anymore. If it turns out you need it, let me know. I am willing to part with it.
Project 2k5
Old 04-07-2009, 09:07 AM   #6
1967 17' Caravel
What would you want for it? I think what I plan on doing will work but knowing me I'll lay it down in driveway while working on trailer and run the thing over with my truck...LOL. That could be a possible back up plan.
Steven
caravel
67' Caravel Dump Valve Replacement 18706 1967-Caravel Waste Systems, Tanks & Totes 17 04-11-2009 11:14 PM
Tire Pressure 67' 17ft Caravel 1967-Caravel Tires 9 03-26-2009 05:24 PM
Black water backup in shower or not 67' Caravel 1967-Caravel Waste Systems, Tanks & Totes 12 03-24-2009 10:27 PM
Squirrel blocker in 67' Caravel 1967-Caravel Winterizing, Storage, Carports & Covers 6 02-26-2009 06:42 AM
67' Caravel top clearance lights (don't work) 1967-Caravel Lights - Interior & Exterior 10 01-31-2007 10:46 AM
