Old 04-30-2012, 07:27 PM   #1
1972 21' Globetrotter
lake charles , Louisiana
thermasan system
does anyone have any experience with such system. i bought a 72 ambassador that has it and i want to disable and remove. any thoughts
virgilc is offline   Reply With Quote
Old 04-30-2012, 07:44 PM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
If my memory serves me right, and it may not, this was a system sold in the 60's and 70's that used heat from the vehicle exhaust to dry the sewage and discharge it as more or less a powder. A little hard to imagine how they got the exhaust back there on a trailer.
I would remove it.
Haven't heard of it in years
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-30-2012, 07:51 PM   #3
x
XXXX , XXXX
The system has an evacuation probe installed into the waste tank. the effluent is than pumped forward to the A frame coupler by a pump mounted on the A frame. There are electical and effluent quick connections to couple to the tow vehicle. The effluent is then injected into the exhaust pipe of the tow vehicle effectively vaporizing it. There should also be a probe cleaning valve located at the rear of the coach.
wasagachris is offline   Reply With Quote
