Old 04-13-2010, 02:38 PM   #1
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
The "P" or "S" trap (plumbing)
We have two 30-gallon gray tanks slung under the Overlander, each with a standard unthreaded opening for a black ABS pipe. On the galley side, it's easy enough to plumb the kitchen sink down to the tank with a normal ABS "S" trap. On the head side, I'd prefer to avoid raising the shower floor any more than necessary (to allow room). Even squeezing in a shallow "P" trap will force me to raise the floor.
These are only gray water tanks so the issue is slightly different than in a household. On the other hand, having some kind of water (or mechanical") seal does afford certain advantages. Any thoughts, master plumbers?
hampstead38 is offline   Reply With Quote
Old 04-13-2010, 03:03 PM   #2
Over59's Avatar
Putnam , Connecticut
Images: 37
I ran a 1/2 hose and a serie of reducers from the shower drain back up thru the floor to a small jetflo pump. Pumps the shower into the gray tank, which I then use to flush my marine head. I set it up so I can drain it with a garden hose connector also or on to the ground. Not enough head room to raise the floor.
Over59 is offline   Reply With Quote
Old 04-13-2010, 07:14 PM   #3
1976 25' Caravanner
Campton , New Hampshire
Grey water can have very nasty odor , you still need some form of trap. Fernco makes rubber traps that may work for you , or even a rubber hose with a low enough bend to stay filled with water.
ticki2 is offline   Reply With Quote
Old 04-14-2010, 10:24 AM   #4
1967 26' Overlander
Upperco , Maryland
I can run a shallow "p" trap, but it will require cutting some floor or building an elevated shower drain pan.
Old 04-14-2010, 10:36 AM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
Me, I'd cut the floor to make room for the trap. You can then box it, and insulate it, if you want.
Newbie electrical questions -- "Use" and "Store"? jjboone101 Batteries, Univolts, Converters & Inverters 8 08-27-2009 09:44 PM
I want "Today's Posts" when I'm "logged in"! 66Overlander Forum Admin, News and Member Account Info 10 06-08-2004 07:32 AM
