Old 05-31-2006, 09:04 PM   #1
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
The effect of using the blue liquid black water treatment on septic fields
Will this blue liquid septic field treatment have a negative effect on septic fields.
wacnstac is offline   Reply With Quote
Old 06-01-2006, 04:05 AM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
If the blue liquid contains formaldhyde then the answer is it will kill the bateria in the tank and make it ineffective. You will have to add a lot of water to flush the tank and then restart the system with new bacteria. Better to dump it in a comercial waste treatment facility that is intended to handle it.
Old 06-01-2006, 05:02 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
A better choice, even though you didn't specifically ask for it, would be an enzyme-based additive, such as Odorlos. It is a concentrated version of what you find in your black tank, as far as microbes, so it will not harm a drain field.
Old 06-01-2006, 04:06 PM   #4
campcollector's Avatar
2003 19' Bambi
Lincoln City , Oregon
Images: 21
try using nothing
Many have gone without an additive and haven't had odor issues.
"No good dent goes unpunished."
campcollector is offline   Reply With Quote
Old 06-01-2006, 06:09 PM   #5
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
you know...
Campcollector has a point. This past summer I used a different kind of enzyme tablet (the name escapes me at the moment) vs. the green liquid "enzyme" that Camping World sells. While the new tablets worked GREAT... the waste smelled, well, like garlic poo when ever I dumped (the trailer's black tank....not ME).
I "forgot" to use the tablets for a trip to OR last winter... and never had any breakdown issues. This past trip to E. WA with for the forum rally, again, I did not use the tablets. No smell (at least, no one pointed one out to me, nor did I smell one) nor dump issues -
My theory is that once you have a "healthy" dump tank, you really don't need to keep adding enzymes.
Marc
Old 06-01-2006, 06:30 PM   #6
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
This is a big deal if it's your household septic tanks we're talking about, and ethically you should not put it in somebody else's septic either. Keeping a septic tank "active" is a bit like keeping an aquarium balanced, except for one thing. If your aquarium isn't balanced, you'll wind up with a tank full of dead fish. If your septic tank isn't "active," you'll wind up with a tank full of "undigested" sh**. That's when you have to call a honey dipper to clean your tanks and start over.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 06-01-2006, 09:21 PM   #7
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Agree~
I completely agree..I think this odor issues is a non-issue..No one bothers to keeps that stuff for any length of time...
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
what holds black water tank in place tw64 1959-69 Tradewind 3 06-16-2004 11:05 PM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
Black water problems Rob Waste Systems, Tanks & Totes 3 08-31-2002 07:34 PM
Water Hammer melprice Water Heaters, Filters & Pumps 10 07-30-2002 01:10 PM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 10:35 AM
