Old 11-16-2014, 07:10 PM   #1
timmaah's Avatar
1999 25' Safari
On , the road
The downside of the Sewer Solution.
Most of the time I love our Sewer Solution, but every so often it is quite the pain in the .....
Our Adventure.. http://www.watsonswander.com/
timmaah is offline   Reply With Quote
Old 11-16-2014, 07:16 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I guess you are just being dramatic but it looks like the issue is with the water hose not the SS.
MICHAEL
Old 11-16-2014, 07:18 PM   #3
timmaah's Avatar
1999 25' Safari
On , the road
I'm saying the problem is it needs pressurized water to work.
Old 11-16-2014, 07:27 PM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Kind of like saying the problem with an Airstream is the tow truck sometimes gets a flat tire.
Doug and Cheryl
Old 11-16-2014, 07:32 PM   #5
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Without Pressurized water
I dump without pressurized water 90% of the time. And I fulltime. And there are a few who are unkind enough to intimate that I might be full of it.
If you want your black tank to be absolutely pristine pressurized water is what you'll need to do it, though you can absolutely use your black tank washers for the destination of your SS.
Simple steps - plenty of water in the black tank so that solids can break down (No chunk flush). Easy on the TP and use only something that is RV friendly. Do the locomotion - Hook up your tow vehicle and rock the trailer back and forth to stir up anything that has settled on the bottom, or if you have an electric tongue jack, raise your stabilizers and raise and lower the tongue jack to create a wave front on the inside of your tank before and while draining. Supply water from above. A bucket or two of water flushed down the toilet will help things along, or if you're hooked up to city water, tuck your shower hose under the toilet seat and prop the drain open while doing a warm water flush.
Oh DON'T #2 in the tank for about 4 hours before flushing. The thing is you want a slurry to drain not a rock field.
After you've drained everything, put 5 gallons clear water back in the gray and black tanks. Drain again close to home, the last of the crud will come out easily.
Paula
Old 11-16-2014, 07:42 PM   #6
timmaah's Avatar
1999 25' Safari
On , the road
The Sewer Solution as it exists in a physical form is working 100%. No debating that.
The Sewer Solution the concept.. which relies on infrastructure not under the manufacturers control is rarely, but sometimes a problem.
Therefore I reserve that right to state that the Sewer Solution can be a pain in the ass to use.
Ugg... sometimes i wonder why i even try to post to this site. It is a funny picture.. a joke.. that is all. Not a rip on a company or person or anything other than something for laughs.
Old 11-16-2014, 07:47 PM   #7
dkottum's Avatar
tim, there is so much bitching about even good products in the forum maybe some of us get tired of it and don't recognize the joke. I'll try to do better.
Doug and Cheryl
Old 11-16-2014, 07:53 PM   #8
timmaah's Avatar
1999 25' Safari
On , the road
And I shall make my original posts more lighthearted. I tried to keep it short and sweet. Perhaps too short and sweet.
The picture was taken at an otherwise well outfitted and great state park just out outside of New Orleans. Bayou Segnette State Park. I highly recommend staying there.
Old 11-16-2014, 08:00 PM   #9
Zil
egg harbor city , South Jersey
Former days, I had no problem with the black tank gravity dump. Did have lots of water to solids.
Zil is offline   Reply With Quote
Old 11-16-2014, 08:04 PM   #10
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I just installed an outside valve that allows us to use the onboard water tank and pump to drive the Sewer Solution. Haven't had a chance to try it out... yet.
But from some careful observation and knowing the maximum flow rate of my well I am guessing it uses less than 15 gallons of water to do a basic tank flush. That is enough to get the tank empty for the road, I can clean it out better at the next full hookup site, or when I get home.
Perhaps not as entertaining as Paula's method tho...
Aaron
WBCCI #XXXX AIR #2495
Old 11-16-2014, 08:04 PM   #11
Wayward's Avatar
Cary , North Carolina
Seems you have the model with the optional shower attachment.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 11-16-2014, 08:06 PM   #12
Wise Elder
Jammer's Avatar
2010 30' Classic
In general, a conventional hose will be quicker and easier when using a dump station.
The "sewer solution" is useful for situations involving longer runs and mild uphill grades where water is readily available. It is also one of several good alternatives for full hookup sites.
Old 11-16-2014, 08:13 PM   #13
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
I laugh every time i see Timmaah's handle cause I can hear Timmaah saying "TIMMAAH"!
SuperTrouper is offline   Reply With Quote
Old 11-17-2014, 05:06 AM   #14
Kevin245's Avatar
Paula
Aaron
Ditto here. I seldom use the water jet attachment on our SS as timing and gravity have always worked for us. The only down side (for us) is that the SS does take more time to drain.
Aaron, let us know how the valve works out as I've toyed with this idea as well.
Kevin
Eleanor Roosevelt
Any downside to getting a 2nd air conditioner? sakthorp Electrical - Systems, Generators, Batteries & Solar 53 07-23-2017 11:08 AM
Downside to installing new axles ? Bill M. Axles 4 05-10-2013 02:53 PM
A Sewer Solution.... Solution FreshAir Waste Systems, Tanks & Totes 15 09-29-2007 10:23 AM
Polishing...the downside Lotek Cleaning, Stripping & Polishing 3 02-23-2005 01:59 PM
