Old 06-22-2011, 12:58 PM   #1
Hillsboro , North Carolina
Tapping into septic
Aside from pulling off the lid and hanging the black water hose directly into the primary tank, does anyone have a fixture they have already cobbled together?
I have tried this, and, well, it stinks (literally!).
There is no room to access the main sewer line from the house to the primary tank, so going into the tank itself seems to be the way to go.
This is a LPP system, so cannot go into the secondary tank or the connector between them.
Appreciate any ideas. Thanks, Steve
TinCanLand is offline   Reply With Quote
Old 06-22-2011, 01:09 PM   #2
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Are we to assume that "no room to access" means that you cannot dig an interceptor line from your trailer location?
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 06-22-2011, 01:29 PM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
Get a pooper pumper and load that tank with a hose.
Old 06-22-2011, 01:32 PM   #4
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Is that concrete or metal in the picture?
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 06-22-2011, 03:33 PM   #5
Assuming the lid is concrete, I would hire a 4 inch diamond hole cutter to go with a powerful electric drill, cut a hole in the middle of the lid, and use some 4 inch domestic piping from the local hardware store to fabricate a suitable connection system with a cap. The joint between pipe and lid can be sealed gas-tight using spray foam such as "Really Great Stuff" from Home Depot.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 06-22-2011, 03:44 PM   #6
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
If you get a sewer solutions system you would only have to cut a 1 inch hole, use 3/4 inch pvc and plumb the adapters with a hose fitting.
Old 06-22-2011, 03:53 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
Surely there must be at least some clearance between the house and the tank. All you need is 12" or so to get a wye in there. Often the lines aren't especially deep so you can hand dig. Then you can run 4" PVC from there to wherever you want to park your trailer, with 1/8" to 1/4" drop per foot.
If there's no way to make that work you might be better off using a cleanout in your house somewhere.
In most cases all you really need to dump is greywater so you can get by with much smaller hose and pipe sizes.
Old 06-22-2011, 03:57 PM   #8
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
You have got to have a sewer line "clean out" access between the outside of the house and the tank. Those are 4 inch fittings. Just plug in there.
Old 06-22-2011, 04:36 PM   #9
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Ditto, just make sure you use a tee with "sweep" fittings and don't spare the new cleanouts, with sweep fittings, also. 1/4" per foot drop will work fine, I've done it.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 06-23-2011, 04:51 PM   #10
Going to look at sewer solutions or macerator pump
Thanks all for the ideas.
More I look at it, we may move the parking spot to a better location (more scenic!) and pump up hill a little bit.
Appreciate any experience/comments with the water jet and/or macerator equipment.
Thanks, Steve
Old 06-23-2011, 04:58 PM   #11
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Thanks, Steve
All you need to know
and yes it works as advertised. A couple years ago we would have weekly pump out parties here at the house. I had not one but four RV's needing to be pumped. We would break out an 8 pack of cold beverages and have the pumping out done before the beer ran out. FWIW it was fellow crew members working on a project. I had plenty of room and lived closer to the jobsite than the nearest campground.
Aaron
WBCCI #XXXX AIR #2495
Where to buy land? george99 Winter Living 31 02-29-2012 08:43 AM
Self tapping floor screws, stripped threads polarlyse Repairing/Replacing Floor &/or Frame 6 05-14-2011 01:10 PM
Winter Travel and Holding Tanks John H. Classic Motorhomes 30 01-09-2011 02:13 PM
