Old 08-04-2006, 11:28 PM   #21
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Finally have fittings!
OK, after much searching I found what is called a Tank Inlet Fitting for $5.50 at Dryers RV Supplies. I ordered two of them. One for the toilet and another for the valve connection. I also ordered a 1.5 inch flange slip fitting for a tank vent I will have to add.
So here are the pictures to chronicle the fiberglassing, which I had never done before.
This first photo shows me tracing the flitting so I can enlarge the hole to 3".
-Tim
theVAP - Airstream Podcast
Old 08-04-2006, 11:29 PM   #22
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Next I cut the hole with the jig saw. Wearing a mask and theVAP tee shirt.
-Tim
Old 08-04-2006, 11:30 PM   #23
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Yes it fits! The orginal metal flange that I ground out had small holes in the flange area to accept resin. I drilled four small holes on the perimeter of the flange to copy that.
-Tim
Old 08-04-2006, 11:32 PM   #24
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Here is the fiberglass repair kit I got at a local auto store for $18. I also used my palm sander with 80 grit paper to clean the areas back to bare fiberglass.
-Tim
Old 08-04-2006, 11:33 PM   #25
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
After mixing the resin with the hardner from the kit, I brushed some of the solution over the sanded area.
-Tim
Old 08-04-2006, 11:34 PM   #26
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
I put the fitting in place, then brushed some more resin on and around it.
-Tim
Old 08-04-2006, 11:36 PM   #27
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
After cutting the cloth that came in the kit to 1" by 6" strips, I soaked them in the resin then laid them out over the edge of the fitting. I applied two coats of of cloth all the way around.
-Tim
Old 08-04-2006, 11:37 PM   #28
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Next I pushed the air pockets out with the little plastic tool that came in the kit.
-Tim
Old 08-04-2006, 11:38 PM   #29
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
I tried to wipe the resin free from the threads of the inlet. However, in the end some did get in. I hope I can chip it out.
-Tim
Old 08-04-2006, 11:39 PM   #30
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Here is the finished product waiting the 90 minutes to cure. It wasn't too difficult after all. Now I have fitting that the toilets closet flange will screw down into.
-Tim
Old 08-04-2006, 11:53 PM   #31
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Here is a shot of the completed slip fitting for the vent pipe that I will have to add.
This part of the tank ended up inside the vanity so I should be able to attach a pipe to it there, run it behind the toilet and up the curbside closet.
The original vent is a deteriorated rubber pipe that runs up in the wall. I'm afraid trying to adapt to keep using that will be a waste of effort. I will also have to add a vent on the street side for the grey tank since one never existed.
-Tim
Old 08-05-2006, 02:03 AM   #32
1960 24' Tradewind
santa barbara , California
hello Safari Tim,
Well thats exactly the right way to do the fiberglass job .Darn near did
it word for word as I had explained it.Not hard to do as you have found out.
Now you can glass whatever else is needed .
Good restoration work !
Scott
scottanlily is offline   Reply With Quote
Old 08-05-2006, 07:24 AM   #33
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Ambassador Tim ~
The shot in post #31 doesn't look like a slip fitting for the vent pipe to me unless you're planning on a very wide vent pipe.
Fine work Tim. You just may get this on the road yet.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 08-05-2006, 10:22 AM   #34
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Originally Posted by flyfshr
Ambassador Tim ~
FF
Thanks guys.
Well Brad, you got me there. I don't know a slip fitting from a ham sandwich. I just hope my wife puts the right one on the plate
I thought that is what it was called. The flange part that I glassed to the tank had a part that look like it could hold a gasket to be sandwitched to another flanged peice like maybe to a valve.
Anyway, my hope is to be able to pvc glue a pipe inside of it to run up and out the roof.
-Tim
Old 08-05-2006, 10:37 AM   #35
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Maybe I'm all screwed up on my terminology. The vent pipe on my tank is a 1 1/2" or 1 3/4" size for venting. Maybe I've been eating slip fittings when all along I thought it was ham sandwiches.
FF
where to buy new aluminum lp tanks.. JohnGalt48 LP Gas, Piping, Tanks & Regulators 3 09-14-2002 10:36 PM
Another reason for aluminum tanks rochleau Our Community 4 09-03-2002 06:30 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 01:56 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
