Old 07-09-2006, 08:38 AM   #15
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Thanks Doug.
I'll check our local stores. At least now I know what to look for.
-Tim
theVAP - Airstream Podcast
Old 07-09-2006, 08:49 AM   #16
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Tim I just checked the piece. I got it out of a box of parts I have here. It's not a 3" cleanout, it's the piece that scews on a blue tank that the hose fits onto. They usually are white and you should be able to get them at any trailer store. The 3" cleanout will work but the hole in the tank would have to be bigger. Right now the piece I used fits the brass ring that is left in the tank.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is online now   Reply With Quote
Old 07-09-2006, 09:35 AM   #17
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Well, now I'm slightly confused again
Do you have a photo of it? Are you going to fiberglass it in place?
When I was at Camping World and asked for the closet flange I got a blank stare. Then asked, uh.. what kind of toilet do you have again?
-Tim
Old 07-09-2006, 10:06 AM   #18
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Tim, this is the piece you can use. It's the part that screws to the blue tank and a dump hose fits on it. The one I used happens to be black so I thought it was a 3" cleanout.
I also think I will hook up a water connection to the tank to help flush it out as it is very flat. The new tailers have such a connection.
Name:	1960 ambassador.jpg
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Old 07-09-2006, 10:16 AM   #19
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Hey Tim, bring your trailer up here, we'll work them out together. I'll make room in the yard for you.
Not sure where you are but it's only 2500 miles from San Francisco.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Old 07-09-2006, 03:26 PM   #20
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Wow Doug!
You got a regular assembly line going there. Thanks for the offer but that is a little far for me!
Thanks for the pics too!
-Tim
Old 08-04-2006, 11:28 PM   #21
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Finally have fittings!
OK, after much searching I found what is called a Tank Inlet Fitting for $5.50 at Dryers RV Supplies. I ordered two of them. One for the toilet and another for the valve connection. I also ordered a 1.5 inch flange slip fitting for a tank vent I will have to add.
So here are the pictures to chronicle the fiberglassing, which I had never done before.
This first photo shows me tracing the flitting so I can enlarge the hole to 3".
-Tim
Old 08-04-2006, 11:29 PM   #22
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Next I cut the hole with the jig saw. Wearing a mask and theVAP tee shirt.
-Tim
Old 08-04-2006, 11:30 PM   #23
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Yes it fits! The orginal metal flange that I ground out had small holes in the flange area to accept resin. I drilled four small holes on the perimeter of the flange to copy that.
-Tim
Old 08-04-2006, 11:32 PM   #24
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Here is the fiberglass repair kit I got at a local auto store for $18. I also used my palm sander with 80 grit paper to clean the areas back to bare fiberglass.
-Tim
Old 08-04-2006, 11:33 PM   #25
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
After mixing the resin with the hardner from the kit, I brushed some of the solution over the sanded area.
-Tim
Old 08-04-2006, 11:34 PM   #26
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
I put the fitting in place, then brushed some more resin on and around it.
-Tim
Old 08-04-2006, 11:36 PM   #27
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
After cutting the cloth that came in the kit to 1" by 6" strips, I soaked them in the resin then laid them out over the edge of the fitting. I applied two coats of of cloth all the way around.
-Tim
Old 08-04-2006, 11:37 PM   #28
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Next I pushed the air pockets out with the little plastic tool that came in the kit.
-Tim
where to buy new aluminum lp tanks.. JohnGalt48 LP Gas, Piping, Tanks & Regulators 3 09-14-2002 10:36 PM
Another reason for aluminum tanks rochleau Our Community 4 09-03-2002 06:30 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 01:56 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
