Old 01-24-2005, 02:15 PM   #1
Over59's Avatar
Putnam , Connecticut
Images: 37
Tanks
Here's the proposed wash / black water system for "The Bat Cave Express". It will allow flushing the black tank with the wash water, pumping out the black with either pump, pumping out the wash directly.
Name:	Bat Cave Waste Water System.jpg
Over59 is offline   Reply With Quote
Old 01-24-2005, 02:45 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Do you crawl underneath the Airstream to access some of the valves?
Old 01-24-2005, 03:22 PM   #3
Over59's Avatar
Images: 37
I such hope I find a place not under the trailer. The Tanks are inside the wheel wells under twin beds. The Y valve's will be under a raised platform (3")in the back which the head will sit on to bring it up to a better height. The handles will be above the deck. The Grey Tank knife valve operates from the inside aisle. The two dump valves are the hardest to place. Looked at the electric operated ones but they are big $$$. Hope to come up with a better placement for the dump valves and outlet. The outlet itself is a little challenge. I want a pull out 1.5" hose but haven't figured out how to do it yet. The major point of this design is the options of moving water around and the redundancy. Running both pumps I'll empty two 55 gallons tanks in 5 minutes in a dual direct dump or 9 minutes running the Grey into the Black and out.
Old 03-25-2005, 06:29 PM   #4
fastrob's Avatar
1976 25' Tradewind
. , Maine to Arizona
Tanks a Lot
Did your plan work out? Has anyone else tried this?
'Tis easier to drain, to fill with anti-freeze than relocate tanks above floor.
Have heard of Alaskan Airstreams with lots of insulation, where are those folk's tanks?
fastrob is offline   Reply With Quote
Another reason for aluminum tanks rochleau Our Community 4 09-03-2002 06:30 PM
LP Tanks Craig LP Gas, Piping, Tanks & Regulators 6 08-22-2002 08:43 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 01:56 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
