Old 02-05-2014, 06:23 PM   #1
ncrenshaw33's Avatar
1974 Argosy 26
jackson , Tennessee
Tank Vents
hello everyone,
In order for the traps on the sink and shower to work does there have to be a vent for every drain? Or can one simply just vent the tank and this will allow the traps to work? and keep smelly gas from coming up through the drains. Thanks,
Nat
New to this world of shiny and elegantly painted travel trailers....
ncrenshaw33 is offline   Reply With Quote
Old 02-05-2014, 07:14 PM   #2
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
you only need to vent the tank.
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 02-05-2014, 07:25 PM   #3
1974 Argosy 26
jackson , Tennessee
Thank you for the quick reply. That is what I had thought but just wanted to make sure.
Old 02-05-2014, 07:37 PM   #4
Central , Mississippi
If your sink drain lines dump into the top of the tank, the tank vent will work fine. Some installs make it real easy to run the line into the tanks' dump fitting. In these cases, you really need a vent on the sink line after the P trap or use one of those fancy hevpro (sp) valves in place of the p trap.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Grey tank for rear bath '66 TW. FreshAir Waste Systems, Tanks & Totes 15 02-13-2012 09:06 PM
Gray Water Tank Flush Road Geezer Waste Systems, Tanks & Totes 6 02-01-2012 06:23 PM
Auxilary Fuel (gasoline) Tank? DGJackson 1970-79 Tradewind 3 08-18-2011 10:44 PM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
No black tank in 62 Tradewind tlsmit1 Waste Systems, Tanks & Totes 1 05-15-2011 04:53 PM
