Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 05-07-2018, 12:41 AM   #1
1970 25' Caravanner
Incline Village , Nevada
Tank vent from side of tank?
Admit up front that this is probably a ridiculous thought, but trying to figure out a way to vent our black water tank from a location other than the top. Is it plausible to put the vent on one of the sides as near the top of that side as possible? Plausible and not a good idea are two different things but wondering if anyone has ever done this.
Jeremy9107 is offline   Reply With Quote
Old 05-07-2018, 05:44 AM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
I’ve never done it. You could do it. Any opening high in the tank would vent, but would reduce capacity of the tank. Also if you have very much horizontal run before you go vertical you run the risk of the vent getting clogged either from an over full tank or while underway with contents in the tank splashing around. Plausible yes, a good idea you have to decide that.
Side to Side Leveling gorrissen Jacks, Stabilizers, Lifting and Leveling 26 08-02-2009 07:50 PM
tank vent out the side? lwebb Waste Systems, Tanks & Totes 8 02-04-2009 09:03 AM
Side to side leveling: can I use the stabilizer jacks? iAirstream Jacks, Stabilizers, Lifting and Leveling 4 08-17-2007 07:33 PM
Side-to-Side Flooring Replacement in Classic MH jeffbolst Repairing/Replacing Floor &/or Frame 12 11-03-2006 01:08 PM
Weight Distribution, side to side JimC Towing, Tow Vehicles & Hitches 8 08-13-2003 03:19 PM
