Old 09-09-2010, 07:02 AM   #1
Bex
1976 Argosy 28
Eckville, Lacombe County , Alberta
Send a message via Skype™ to Bex
tank sensors
Whilst trying to repair a leak in the tank outlet valve I noticed the tanks (at lest the black water) are wired for sensors, unless the wiring is for something else.
My question would be where do they terminate?
I have a 28ft Mid bath Argosy, 1975/6 (vin is '76 year of manufacture is '75, apparently)
Bex
TAC AB-1
A wise man once told me he wanted to stay fit enough to run a marathon on his hundredth birthday. Another said he wanted to be shot by a jealous husband on his, I'm with the latter. God bless you Richard.
Carpet Cleaning is what I do, it's not who I am.
Bex is offline   Reply With Quote
Old 09-09-2010, 07:14 AM   #2
x
XXXX , XXXX
the wires will go back to your monitor panel which has tank level guages. Mine went up through the floor into a closet and then up in to the walls to travel up to the monitor panel.
wasagachris is offline   Reply With Quote
Old 09-09-2010, 07:46 AM   #3
Bex
1976 Argosy 28
My unit has no monitor panel, just a breaker box, would it be next to that?
TAC AB-1
Old 09-09-2010, 08:02 AM   #4
Ottawa , ON
Bex,
I wouldn't worry about those sensors too much. They are almost guaranteed to not work.
Even the newer trailers, which use a much more sophisticated way of sensing, are famous for sensor problems.
Two things that are guaranteed to show your tank condition: a flashlight down the toilet for the black tank, and if you see water in the shower, they grey tank is full.
You're on your own for the fresh water tank
Old 09-09-2010, 01:36 PM   #5
Bex
1976 Argosy 28
Thanks for the posts.
I was curious, thats all. Nice to know where stuff is, even if not intending to use it.
Bex
TAC AB-1
Holding Tank sensors andyfuson Waste Systems, Tanks & Totes 43 01-09-2009 10:16 PM
Tank Monitoring sensors 59er Fresh Water Systems 4 04-10-2008 09:29 AM
original tank sensors goransons Fresh Water Systems 4 07-20-2007 09:25 PM
Tank Sensors Dan G. Waste Systems, Tanks & Totes 47 07-19-2007 06:05 AM
Holding Tank Sensors seamusthegray Waste Systems, Tanks & Totes 7 11-08-2004 03:38 PM
