Old 05-11-2007, 08:29 AM   #1
2005 28' Classic
Jacksonville , Florida
Tank Sensors
Who else is having problems with Tank Sensors? Mine seem to read ½ or ¾ full always. These darn things have not worked since day one. Dealer fixed once and lasted one day. Broke before I even used the tanks again so I know it is not a sensor issue. In all the trailers I have had over the years I never had as many little issues like I do with this trailer.
Dan G. is offline   Reply With Quote
Old 05-11-2007, 08:33 AM   #2
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Black or grey?
Be sure to use plenty of water when you flush (before and after) and always start with a few gallons in the bottom of the tank.
I dump a few buckets of water in before I dump black tank also. Either that or use a Flush King. I also use Geo method a couple of times/season.
My gray is pretty accurate, seems like my black tank gauge, despite my efforts, is always finicky.
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 05-11-2007, 08:48 AM   #3
2005 28' Classic
Thanks for the reply, Bill. It is both. I keep them very clean and have with all my trailers over the years. I use a flush king. Pretty sure it is not a debris issue.
Old 05-11-2007, 09:16 AM   #4
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
Grey, OK but black never shows less than 1/4.........since day one! I just look down the toilet to see what is happening.
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 05-11-2007, 09:23 AM   #5
2007 34' Classic
Pecos , New Mexico
I have had 4 new AS trailers and not one of them reads accurately for grey or black after a few uses. We just learn to pay attention to avoid standing in a puddle of grey water while showering.
Pecos Pete
Cow Creek, NM
'07 34' Classic
Pecos Pete is offline   Reply With Quote
Old 05-11-2007, 09:40 AM   #6
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
The black tank can be cleaned with a bag of ice and a bucket of water. Dump thse in just before you head out for the road. I have not figure out how to get get ice into the grey tank short of removing the vent cap and dump in down the stack. Then check the sensors...
Michelle TAC MT-0
Sarah, Snowball
Old 05-11-2007, 09:44 AM   #7
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Lightbulb Ice
One trick I learned was to put a bag of ice in the black tank, via the toilet, before I leave to go to a campground. Let it slosh around in there. Dump the black first off. Cleans the internal terminals pretty well. (sometimes I put some baking soda in with it)
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 05-11-2007, 10:14 AM   #8
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
The ice trick will not work with these sensors if the hope is to fix the sensors this way, as they are not simple electrodes that close circuits as water levels rise. This Micro Pulse system I believe uses other type sensors that calculate levels based on pressures. I had the exact same problem as has been described in this thread. I also found that temperature played a critital role in output. So, if the system was calibrated when it was 80 degrees out, when it was 50 degrees out, the system would not be accurate, but if it was within about a 25 degree difference it worked well.
Here is a thread I started a while back. The calibration docs I got from the manufac of the tank monitor system are no longer on my server on the links on the thread and I think someone else took them and posted them to another site.
If you can't find them, PM me your email address and I will send them to you.
http://www.airforums.com/forums/f163...ion-14877.html
Old 05-11-2007, 02:00 PM   #9
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Dan,
Here is the link to the manufacturer's web site that has a PDF document regarding configuration. Note that your monitor panel is under a 5 year warranty from the manufacturer. Obviously if the dealer fixed it and then you had problems again, apparently the unit is not storing its configuration properly. These folks should be able to get you fixed up with a replacement panel. One of my lights failed and they quickly sent me a new panel.
CATCON Products | Home
Twink is right about the ice cube solution. It's not the fix for this new breed of sensors.
Regards,
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-14-2007, 11:37 AM   #10
1 Rivet Short
1989 25' Excella
Bill
Well guess what? It must be my turn. As noted black and grey sensors work OK most of the time. I have never had problems with my Fresh tank gauge...until this weekend!
Worked fine 2 weeks ago. Fill up this weekend...nothing, still reads "E". Never lit up all weekend.
As you can guess, black and grey are not really a big deal.
Fresh water however, is a little more critical!
Any ideas?
You can't really put any cleaners in your fresh...
I guess I could do the ice cube thing next time?
Thanx, Bill
Old 05-14-2007, 12:56 PM   #11
jcanavera's Avatar
Fenton , Missouri
Images: 143
I guess what would be nice to know, and I assume someone has done this, how do you diagnose a sensor problem in the vehicles that use the older technology? Obviously it can be the sensor, the wiring, and finally the panel itself. If you've done this task, post the steps you went through. I'm sure it will help a lot of folks who have just found out, or will find out shortly that things have gone astray.
Now those of you who have the newer trailers, I'm not sure when that new technology came out, (I'm assuming 2002 or 2003) but the bulk if not all of us are still under manufacturer's warranty (the panel only), so worse case you can get a replacement.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-14-2007, 01:16 PM   #12
Aluminut
2004 25' Safari
. , Illinois
The new tank sensors came out mid 2004 model year. Anything prior to that time would be the old sensors. I say that because when I went to get the Safari new, I was told these were only placed into service very recently. How true or false that is, I can't say.
Bill isn't your unit a pre-2004?
Old 05-14-2007, 01:38 PM   #13
1 Rivet Short
1989 25' Excella
Yep-89...
Got to thinking-it won't be easy getting ice cubes in the fresh water tank!
Old 05-14-2007, 01:42 PM   #14
Aluminut
2004 25' Safari
. , Illinois
Won't be easy anything with the fresh tank if it's parked above the axles....
If you're unit is like mine, it looks kind of a job to get to the tank. If you're unit is more like our Bambi, then it would be a breeze....but me thinks it's the first.
Help... I Need To Install A Gray Water Tank???? kangol Waste Systems, Tanks & Totes 0 04-19-2004 08:10 PM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 06:52 AM
White water tank cleaning... Andy R Fresh Water Systems 9 05-17-2002 08:14 PM
