Old 07-11-2007, 08:10 PM   #43
lsinclair's Avatar
2008 30' Classic
Pagosa Springs , Colorado
Tank sensors
There has been much offered on tank issues, but little on resolutions. One quick check (diagnosis) on newer models is to swap the wires on the back of the monitor panel between one tank operating correctly and one with no reading or an inaccurate reading. If the tank in question now reads correctly, your monitor panel is good. The problem would be in the wire to the senosr or the sensor itself in the affected tank. As previously mentioned by others, these are pressure sensors.
Good luck,
Larry
lsinclair is offline   Reply With Quote
Old 07-11-2007, 08:18 PM   #44
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Mine just recently stopped monitoring the fresh tank. Was working one minute, then poof, no more fresh tank info.....
I must say this tank sensor system really has been problematic, but the company (tank sensor company) has been fairly good about getting me the support I've needed.
Old 07-11-2007, 09:02 PM   #45
lsinclair's Avatar
2008 30' Classic
Tank sensors
One of the most common problems yet easily ovelooked is secure connections. Poor connections and moisture/corrision can cause fits. All my electrical work performed is done using "shrink" connectors. They pose the least problems if done right. Intermittent connections open a circuit and can ruin a perfectly planned trip!
Old 07-12-2007, 06:05 AM   #46
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Larson schematics
Anyone have the schematics for this board?
I pulled it last night and will try to diagnose at board level...
Thanx, Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 07-13-2007, 09:35 AM   #47
1 Rivet Short
1989 25' Excella
Looks like the chip is the problem...unforunately it is proprietary and no longer in production (that I can find).
I am going to replace with my own gauges reading directly from the tank out puts.
Does anyone know the range of the outputs?
Thanx, Bill
Old 07-19-2007, 06:05 AM   #48
1 Rivet Short
1989 25' Excella
May have tracked down a monitor panel in a salvage yard...does anyone know if a 92 and 89 are the same?
Really just need the board...
Thanx, Bill
Help... I Need To Install A Gray Water Tank???? kangol Waste Systems, Tanks & Totes 0 04-19-2004 08:10 PM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 06:52 AM
White water tank cleaning... Andy R Fresh Water Systems 9 05-17-2002 08:14 PM
