Old 01-29-2018, 05:10 PM   #1
vincaroo's Avatar
1991 25' Excella
1995 34' Excella
Atlanta , Georgia
Tank Sensor Wires
Hey All,
I'm renovating my 1995 34' Excella. I've found that my water tanks all have 3 single wires attached at several different levels on the tank, and then they connect in one connector (towards the top center of the picture in red). A single seperate wire runs to the monitor panel (in the bottom of the picture). Is this correct? I'm just not familiar with this kind of wiring set up and I want to make sure this is right before I cover it all back up under the floor. Thanks in advance for your help.
vincaroo is offline   Reply With Quote
Old 01-30-2018, 06:42 PM   #2
Chip and Jeff
ctcbcl's Avatar
1991 25' Excella
Atlanta , Georgia
I have the same wierd red bundle...no idea...anyone?
Chip & Jeff
Fur-Children: Porter and Spencer
Atlanta, GA
ctcbcl is offline   Reply With Quote
Old 01-31-2018, 08:18 PM   #3
Chip and Jeff
ctcbcl's Avatar
1991 25' Excella
Atlanta , Georgia
No one has seen this?
Chip & Jeff
Atlanta, GA
Old 01-31-2018, 08:21 PM   #4
1981 31' Excella II
New Market , Alabama
Well fill the tanks with water and see if they read correctly.
Perry
Old 02-11-2018, 08:50 AM   #5
vincaroo's Avatar
1991 25' Excella
1995 34' Excella
Atlanta , Georgia
Perry,
I would but we have the trailer so torn apart that the tanks currently can't handle water (a lot of cut plumbing lines). After doing some homework on the forum, i'm going to upgrade to the See Level II system. It looks like it's the best solution....just replace it all!!!
Old 02-11-2018, 08:24 PM   #6
1981 31' Excella II
The sensors on my 81 still work fine. One tank had a couple wires reversed from the factory and I had to replace an Opp amp or two in the control board. Good luck with it.
Perry
Old 02-11-2018, 08:44 PM   #7
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I've had very good luck with my SeeLevel. I'm installing my second one in my Overlander for all three tanks, fresh, gray and black. I did the same with the 66 Trade Wind.
The tanks I ordered had the old style "resistance" probes molded in. You can see the buttons in the photo. The SeeLevel circuits just adhere to the outside surface of the tank.
David
Name:	1404 Waste Tanks See Level Senders (Mobile).JPG
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Link to our 1976 Renovation Project:
http://www.airforums.com/forums/f221...ct-202081.html
New MicroPulse Sensor and re-cal... post mortem on old sensor RFP General Repair Forum 10 10-25-2017 08:29 PM
7 Wires in, but 4 wires to lights..??? KZGoodchild Lights - Interior & Exterior 1 05-03-2017 05:10 PM
Shorten temperature sensor wires Mgieselman Electrical - Systems, Generators, Batteries & Solar 2 10-27-2016 04:26 PM
Fresh water tank: Level sensor wires Keyair Fresh Water Systems 6 12-19-2010 12:12 AM
gas tank sensor wb13798 Mechanics Corner - Engines, Transmission & More... 21 08-21-2003 07:04 PM
