Old 09-10-2015, 03:40 PM   #1
1977 31' Excella 500
Bonnyville , Alberta
Tank Replacement 1978 Excella 31'
Hi Guys
Can I drop the tanks out the bottom by removing the 2 pans at the mud and rear of the trailer?
Thx!!
Zenstream1 is offline   Reply With Quote
Old 09-10-2015, 04:54 PM   #2
Originally Posted by Zenstream1 View Post
Hi Guys
Thx!!
Yes.
Old 09-10-2015, 07:51 PM   #3
1979 23' Safari
Wayland , New York
Yes, the gray and black water tanks will be under the rear pan. Fresh water tank in the middle pan.
Make sure the tanks are empty before dropping the pans. Then you'll have to disconnect the plumbing.
For the fresh water, disconnect the fill and suction lines from inside the trailer first.
HiJoeSilver is online now   Reply With Quote
Old 09-10-2015, 09:05 PM   #4
Thanks man!
Old 09-10-2015, 09:33 PM   #5
1979 23' Safari
Wayland , New York
Look long and hard at the gray and black piping to figure out how to get it apart without cutting the pipes apart. It may be difficult but should be possible. A good starting point is to unbolt the drain valves.
1978 31' 1978 Airstream Sovereign Land Yacht - South Florida JoshuaSteven Airstream Classifieds 0 08-12-2015 07:58 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
how many gallons is blackwater tank on the 1978 airstream excella 31 foot? jws Waste Systems, Tanks & Totes 4 07-14-2014 08:44 AM
1978 Argosy Minuet 6.0 Metre :: 1978 Argosy by Airstream Minuet 6.0 Metre overlander64 Airstream Registry Discussions 0 08-19-2011 08:30 AM
1978 22 foot Argosy vs 1978 22' Minuet drussel All Argosy Trailers 37 12-02-2009 08:34 PM
