Old 11-05-2012, 11:54 AM   #1
jornvango's Avatar
Tank level on control panel
How reliable is the tank level indicator on the control panel?
Yesterday, we emptied our black & grey tanks at the dumping station on the campground.
Shortly after, when we checked the tank levels on the control panel (just to make sure), it shows that "Tank 1" (which I assume is the black water) is still 2/3 full !?
It took a few minutes to dump the black water, so I assume it's empty. Before I closed the black water hookup during dumping, I made sure nothing was coming out anymore, so could we have a clog or should we not rely on the control panel to give an accurate level?
Jorn
P.S. We have a '95 Sovereign.
jornvango is offline   Reply With Quote
Old 11-05-2012, 12:49 PM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
You could have both problems. I would put a bag of ice in the tank and drive around a little before I dumped the next time and then flush it from the inside while still hooked up to the dump. The sensors on that year Airstream are also not totally reliable, so I would drive around with a nice clean tank of water for a while to help clean them up before I dumped again.
Old 11-05-2012, 12:51 PM   #3
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
Tank level indicators are notorious for failing/giving erroneous readings.
The sensors inside the tanks can easily get covered with crud.
To verify that your black tank is empty simply look down the toilet with a flashlight. If there is no fluid then it is empty.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 11-05-2012, 02:00 PM   #4
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I'm finding the same issue with our '01 Excella. Is there a remedy for this ???? Is it something we can repair ourselves ???
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 11-05-2012, 02:23 PM   #5
StreamRollin's Avatar
1999 25' Safari
Denver , Colorado
Thumbs up Cleaning sensors off.
I ran into the same problem with the sensors not reading the level of both the black and the gray tanks. Late last year after so some research on keeping tanks clean and also the sensors so they work properly,on our first trip of the season I put in each tank 1 cup of powered laundry soap and 2 or 3 cap fulls of fabric softener along with the other chemicals that I always put in. Well after a few weekends when the tanks were full I was so surprised at the amount of black gunk that was flowing out of the gray tank. the rest of the camping season I did it 2 more times. Now when I dump my tanks my gauges read empty and work great. I think the fabric softener creates a protective film over the sensors. Now that the tanks are clean I think that once a year treatment should be enought.
Jim D.
AIR # 56543 TAC# CO-10
StreamRollin is offline   Reply With Quote
Old 11-05-2012, 02:28 PM   #6
1974 Argosy 20
Kooskia , Idaho
That is an understatement.....LOL... they work once in a while, if you are lucky, and the moon is blue and the tide is high and it is not raining would be more like it.
Sorry, I just never had any luck with tank sensors on the gray or black water side. Fresh water tank would generally give me a rough idea of level there, but even then there are very few original equipment sensors on any RV's that work well. I guess some after market ones can be ok, but have never had the pleasure of such.
Old 11-05-2012, 02:30 PM   #7
1974 Argosy 20
Kooskia , Idaho
Oops, I was speaking in general terms, not specific to the original poster's rig.
Old 11-05-2012, 08:18 PM   #8
retired USA/USAF
2001 30' Excella
My fresh water tank seems to be reliable. We had a 1985 Excella and the gauges were good even after all those years. Now on the newer one they seem to be fouled up. I will try the detergent and fabric softener in Feb. if we take our trip south again. Since they are there I'd like to see them, at least, be somewhat reliable.
Thanks all for the input.
Happy Halloween ( delayed due to hurricane Sandy )
DON'T FORGET TO VOTE. God help us all.
Roger in NJ
TAC - NJ 18
Old 11-17-2012, 09:18 AM   #9
Brookfield , Wisconsin
Stay tuned all as a different approach to monitoring tank levels will be introduced soon, where the approach utilizes proven techniques used in the sewage treatment industry for years and years. The system went through "numerous" modifications to reduce cost but to make installation as easy as possible, which is a major concern for the DIY's on this site. Sorry for the delayed introduction of the system but I had to "pay the bills" as well as design some high priority products for your market. The system has also included functionality to diagnose and maintain the system to readily identify faults should any occur, although we have not been able to create an actual fault in the system through our testing scenarios. If a fault should ever be detected we strive to provide the support necessary to enable DIY repair of the system. Additionally rather than intentionally design the system for "replacement" with a future system, we shall provide an "update service" to enhance your system with new "features" for which your hardware will be capable of performing rather than "replacing the unit". In effect the sysem is designed to meet the desires of the DIY individual as well as the OEM.
Again, despite making every effort "alpha testing" (hand built final design) revealed some flaws in our "customer requirements" where the initial unit to be introduced was cost optimized, but in reality, DIY individuals preferred the "two module unit" as it was easier to install due to "physical access" issues. Thus some "more repackaging design work", changes to existng designs so say components are used in all system configurations, and of course, now more testing. As they say; "At some point you need to shoot the engineer". So stay tuned as I believe the system will far exceed your expectations of any tank gauging systems and should be available shortly. Since all design decisions consider quality, reliablity and ease of installation first we will soon be posting detailed information of initial units for comments from "real users" for the next versions, where your comments are always given serious consideration and numeorus comments from this web site on existing systems is what motivated the development of this product line. So please, stay tuned as you comment will be appreciated.
C5Don is offline   Reply With Quote
Old 11-17-2012, 04:03 PM   #10
Skater's Avatar
1995 30' Excella
Bowie , Maryland
We have a '95 too, so we probably have the same system.
Our fresh water indicator works fine.
Our gray always indicates (at least) 1/3 full. Our black tank always indicates 2/3rds full (or more, I forget). I suspect the sensors are gummed up.
I've used the tank sprayer with no luck. My next attempt involves some of that "sensor cleaning" chemical. You put it in and let it soak while you drive around with the tanks full, then dump. I have the chemical but haven't gotten the chance to try it yet. I keep meaning to put it in and fill the tanks as prep for a camping trip, but I either forget or am going camping somewhere that doesn't have sewer hookups. And the bottle says you shouldn't use it at less than 70 degrees.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 01-11-2013, 10:10 AM   #11
SilverPal2's Avatar
1954 22' Flying Cloud
2012 25' Flying Cloud
Ojai , California
C5Don I would like to hear more about your new design
WBCCI 2705 AirForums 24539
SilverPal2 is offline   Reply With Quote
Old 01-16-2013, 08:05 PM   #12
Wild-Air's Avatar
2012 25' FB Flying Cloud
Minden , Nevada
I would like to hear more about C5Don's new system, too. The MicroPulse system installed on my 2012 is stupid, it's located in a stupid place, and is just begging to be superseded by something that actually works.
Russ
Wild-Air is offline   Reply With Quote
Old 01-17-2013, 07:05 AM   #13
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
The system in our '97 hasn't worked for years.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 01-17-2013, 07:54 AM   #14
retired USA/USAF
2001 30' Excella
Well, still sitting on the edge of my seat waiting for the solution. We'll be heading south in a few weeks and I think I will try the washing detergent and softener as it seems to be the simplest. Hope it works.
See ya'll on the road sometime
Roger in NJ
TAC - NJ 18
