Old 07-14-2006, 09:28 PM   #1
1977 31' Excella 500
plano , Texas
Tank Gauges
I have had my first AS for 5 weeks now. Luckily my issues to this point have been simple. Now I am trying to fix the tank gauges. The potable tank reads correct, but the grey/black gauges are bottomed out (independant of the level). I don't think they are working correctly. How do I debug them?
-thomas
tschat is offline   Reply With Quote
Old 07-14-2006, 10:25 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Thomas,
Here is how the gauges work (in my 75), when you flip the switch for a tank it send power to a sensor harness for that tank. The tank has several sensors at different heights in the tank. Each one of these sensors has a different resistor connected to it. The amount of power returned to the gauge is dependent on which sensors are covered.
I would start with the switch and make sure it has power. Then see if any is being returned to the gauge. Is it possible that the tanks were replaced and have no sensors or the sensors were not attached at the harness?
The gauges on mine work ok most of the time, but are not that accurate. When you see water in the shower, the grey tank is full. When you see... , the black tannk is full
Richard
Old 07-14-2006, 11:41 PM   #3
Thomas, the indicators on my Excella are different to those described by azflycaster. On mine, when the switch is held down, twelve volt power passes down a wire to a sensor at the bottom of the tank. To indicate the level, there are a series of sensors at empty, 1/4, 1/2, 3/4 and full levels in the side of the tank near the dump valves. These sensors are just electrical grounds, and each one has an attached wire that leads back to an indicator light in the control panel. When fluid completes the circuit between the live sensor and one of the indicator ground sensors, the relevant light illuminates. You can see why all the lights illuminate when the tank is full, and, for example, just the E, 1/4 and 1/2 will illuminate when the tank is half-full. To debug, you need to ensure that power is reaching the live sensor, that the sensor ground returns have continuity, and that the bulbs in the control panel are not defective. You will need to know the color coding for the circuits. The Airstream Manual for my trailer has a wiring diagram with color codes for the control panel and tank monitor system, and has several pages of de-bugging procedures. It is very good. If you do not have a manual, I recommend you obtain one. It is invaluable. Copies are available as described by Janet at http://www.airforums.com/forums/229490-post2.html
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 07-15-2006, 07:05 AM   #4
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
I need to recreate the control panel end of this system, the early 70s version with the four sensor wires (the sensors are just screws that poke into the tank and make contact with the water). I was thinking of doing it with CMOS versions of the 7400 series logic chips and LEDs for indicators. Anyone out there done this yet? It would be nice if you could turn it on and it would flash the proper LED (just one, not the current level and all those below that level) every 5 secs or so. And green, yellow, red LEDs, too...
If anyone has a spare "roundtoit" I'll do it.
Old 07-15-2006, 12:22 PM   #5
plano , Texas
I have 2 wires going from the panel to the tank. One is switched power, the other is the wire that goes to the gauge. When I go back to the tank, I have 4 wires. The switched power wire goes to the bottom "plug" on the tank. The other 3 wires go to higher "plugs" on the tank. These 3 are connected together and connected to the "sensor" wire. I get the 12v back at the tank, but still nothing on the gauges.
-thomas
Old 07-15-2006, 12:56 PM   #6
2002 25' Safari
Dewey , Arizona
Images: 62
Here is what the book says to do-->
1. Disconnect the connector at the tank
2. Place a 2.2 K ohm resistor across the connector
3. Test the tank level
It should read full or be ajusted to full (screw under gauge)
If it is ok or adjusts ok, the pannel is good and the sensors may need to be cleaned or replaced.
Richard
Adding a gray water tank??!! kangol Waste Systems, Tanks & Totes 2 04-21-2004 06:11 PM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 03:40 AM
Pressurized water tank eracism Fresh Water Systems 2 10-25-2002 06:09 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
