Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 04-08-2004, 07:25 PM   #1
cosmotini
cosmotini's Avatar
Profile:  2008 27' International CCD FB
Highland , Illinois
Images: 83
Tank flush question
Do the aftermarket tank flush products work as well as the factory tank flush?
Our 28' International CCD does not have one even though the paperwork says it did.
The factory and dealer have offered to put one in, but it sounds like a lot of work for them. I wouldn't be opposed to an aftermarket if it worked as well.
Dennis
cosmotini is offline   Reply With Quote
Old 04-08-2004, 07:32 PM   #2
Tarheel
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
The "spray wands" are susposed to be good, but I have to admit that I am lazy and like the built in ones that are on our unit. I have heard of some that use rid-x for home septic tanks and place a little in their tanks with 5 gallons or so of water for the trip home. The "sloshing action breaks up solids along with the rid-x. Either dump when you get home or the next time you go out. All of the solids should be decomposed by then. I have never had a problem but I make certain that the tank is almost full before dumping, even if I have to add system water to the tank to fill it/
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Holding tank plumbing question yukionna 1999 - 2004 Bambi 15 09-10-2003 09:00 PM
Black tank flush.... drboyd Waste Systems, Tanks & Totes 11 08-01-2003 08:40 AM
Easiest way to flush black tank? JLD Waste Systems, Tanks & Totes 10 02-19-2003 08:16 PM
Black Tank Flush System Ed & Nancy Our Community 6 02-19-2003 09:36 AM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 07:52 AM
