Old 03-25-2019, 07:23 AM   #1
1976 31' Sovereign
Maribel , Wisconsin
Tank Drain Connections - 1976 Sovereign Center Bath
Hello Everyone,
I'm in the process of replacing the axles, and all of the running gear, on my 1976 Sovereign International Landyacht Center Bath. Well, once I removed the axles I thought, hey I should remove the belly pan and clean up the whole frame, instead of just doing the area in the wheel wells. I should also mention that due to bad or no winterizing by a PO the copper plumbing needs to be redone with PEX, so you see how one thing leads to another. Remember, this started with replacing the axles. Anyway, the second step in my service manual, under Main Waste Tank Removal and Replacement simply states 2. Remove Drain Lines. The interior of my Sovereign is immaculate so I do not want to rip up the floor. My question is, where do I access the drain lines for the black and grey tanks? Can this be done without removing the floor? From the reading I've done, I know this has to be done from the inside, somewhere, but I can't find any specifics. If I disconnect the toilet and flange, the shower and lavatory drain, and the galley sink drain, will the tanks be free to be safely lowered?
Thanks for any wisdom you have to offer.
Nick
NTVB73 is offline   Reply With Quote
sovereign
Center bath Sovereign - converting black tank to grey tank bjen5en Waste Systems, Tanks & Totes 2 11-01-2017 11:46 PM
1976 Airstream Sovereign 31 center bath eBay Watch Airstreams on eBay 0 10-26-2013 03:50 PM
Center bath or rear bath Sovereign? desertratt General Repair Forum 9 09-24-2011 09:40 PM
want to trade center bath for rear bath? nomader General Repair Forum 7 02-23-2010 05:40 PM
drain connections, black pipe, etc Chuck Waste Systems, Tanks & Totes 6 04-08-2004 03:45 PM
