Old 03-01-2010, 02:50 PM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Tank Capacity 65 Ambassador
Does anyone know the fresh water and black tank capacities for a 65 Ambassador?
bwaysteve is offline   Reply With Quote
Old 03-01-2010, 03:03 PM   #2
The fresh water tank holds 30 gallons.
The water heater tank holds another 10 gallons.
The best way to check the black tank capacity, is to dump measured amounts of water into it, thru the toilet.
Old 03-01-2010, 03:19 PM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
My stock '67 will hold 30 gallons of freshwater, and 17 gallons of black.
There are Airstream dealers who sell new, stock black tanks for '65 Airstreams. Maybe one of them will see this thread, and post what an original Ambassador's black tank was designed to hold. Chances are you have your Airstream's original tank.
Tom
Old 03-01-2010, 03:32 PM   #4
Tom
Airstream has not had black water tanks availble for many years for 1968 and older models.
In fact, at this point, they do not have but a few tanks available for the 70's.
After market black and some gray tanks are avialable, most made with fiberglass and some with plastic.
Old 03-01-2010, 04:31 PM   #5
TomW's Avatar
1967 26' Overlander
Memeber requested knowlege, not a replacement
Originally Posted by Inland RV Center, In View Post
Airstream has not [yada yada yada]...
bwaysteve,
Apparently you will need to measure your black tank's content unless another '65 owner sees this thread.
Good luck,
Tom
Adding more water tank capacity rpcarlson Plumbing - Systems & Fixtures 8 09-21-2008 12:14 PM
Airstream 280 Tank Capacity purplehippy Classic Motorhomes 7 02-07-2008 03:17 PM
Tank capacity questions travelannie Member Introductions 10 08-07-2006 07:00 PM
Model Confusion and tank capacity Islander Classic Motorhomes 4 06-18-2006 04:10 PM
Tank capacity calculator 74Argosy24MH Link Archive 0 05-03-2003 06:59 AM
