Old 05-29-2015, 04:05 PM   #1
PopHetzler
Emh142's Avatar
2003 34' Classic S/O
Troy , Ohio
T-Handle on black water tank Broke.
I pulled to empty the black water tank on my 2003 and one side of the T broke off. I epoxied a small steel Rod on the broken side and it worked for a while. Any ideas for a fix???
Emh142 is offline   Reply With Quote
Old 05-29-2015, 04:14 PM   #2
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
These are purchasable from most RV supply stores, Google it for online suppliers.
Mrjkq is offline   Reply With Quote
Old 05-30-2015, 11:27 AM   #3
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
The handle stem should be threaded, and the handle should twist off that. I just just a piece of aluminium flat bar, and tapped it to thread onto the shaft. I then put a nut on the top to secure it.
If I was doing it a again, I would use a chunk of aluminum round stock, maybe 5/8" as it would look nicer.
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 06-01-2015, 04:50 PM   #4
PopHetzler
Emh142's Avatar
Troy , Ohio
I'll take a look at it. I hope it is threaded. I can probably find some rod. Thanks for the idea. Otherwise it may be a job for small vice grips. DH
Old 06-01-2015, 05:45 PM   #5
Pileus's Avatar
1985 31' Excella
Seguin , Texas
Out-Of-Doors Mart T handle Kit for Black and Gray Dump Valves 003795
003795 T handle Kit for Black and Gray Dump Valves. This is the handle and the holder for the T-Handle only; there is no rod with this kit.
I paid
$10.95 (plus $5.50 shipping)
Pileus is offline   Reply With Quote
Old 06-02-2015, 06:27 PM   #6
1996 25' Excella
Tillsonburg , Ontario
I broke mine a while back; the kit in Pileus' post is exactly what I purchased
JCW
JCWDCW is offline   Reply With Quote
Old 08-06-2015, 11:31 AM   #7
1999 28' Excella
New Orleans , Louisiana
Also broke a t-handle on black
I ordered the kit from ODM the other day. Expect I will have it soon. Can someone help with how to put this on. I am one not to cook without recipe but can follow directions?
Help!
BadKat
badkat is offline   Reply With Quote
Old 08-07-2015, 03:18 PM   #8
1999 28' Excella
OK, it is the easiest fix I have had so far! Hope it works...hehe
Old 08-07-2015, 07:29 PM   #9
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
CampingWorld has everything but what you need. I got my replacement handle via Amazon. Just search Amazon for Valerra and what you need will eventually show up.
TinCan
graysailor is offline   Reply With Quote
Old 08-08-2015, 06:36 AM   #10
1999 28' Excella
Got mine at ODM and sent the day I ordered it. I think I am going to start an AS parts box..ordered 2 but only needed one..was only $11.95.
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
I Broke the Greywater Dump Valve Handle 1Michigander Waste Systems, Tanks & Totes 10 06-26-2014 06:24 PM
Black Water Tank Valve Adapter Broke!!! crabbey1 Waste Systems, Tanks & Totes 5 05-31-2013 03:56 PM
Dump Valve Handle - broke... Craig Waste Systems, Tanks & Totes 11 01-22-2011 07:46 AM
Door handle finally broke oliver00 Classic Motorhomes 4 07-30-2010 12:06 PM
