Can a holding tank shaped like the one in the attached picture be supported or hung by the 2" lip around the top or would you also need to support the bottom of the tank somehow?
I just finsihed putting mine in with straps across the bottom. I used two 1/8" x 1" flat bars in the middle and two 3/4" x 1/8" angle iron on the sides.
These things get really heavy when full and the plastic ones may even bulge out.
I think mounting supported across the bottom is the way to go.
well after a snooping around all of the SOB trailers at my storage place i found out that is exactly how they support them... they either had 2x2 angle iron or 2x2 tubing to support the grey and black tanks... must be some thick plastic.....
Tim take a look at the picture where they show you measurment C. see how you have about a 2" flat spot on both sides (kinda like a T) before it drops down to form the tank? Well they ran angle iron of tubing across the frame rails that support the tank from those flat spots....
here i did one up in paint.... the red boxes is your angle iron or tubing.... maybe that helps.... i was supprised to see them hanging there like that but, they were all pretty much the same and i looked at about 15 of them..
Here's a photo of mine so far.
your drain for the shower looks like it enters the tank what will below the waterline when the tank fills up.... how do you keep it from flowing back to the shower?
I put in a new black tank. I called the factory that made it and they said that people mount that type of tank all the time from the lip. Mine just has the lip down both long sides so I used 2" angle covered with 1/8" rubber strips glued to the angle. It feels real good but when I build the cover on the bottom I may put something there to help but I will see.
Hmmmm Been thinkin of puting a gray in my 73..... Nice work!
'74 Overlander (Rear Bed)
'77 20' Argosy MH (Looking for a new home)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281 w) www.balrgn.com www.balrgn.com/Airstream.htm
I'm hoping that since the tank is vented at the top, up through the floor, and the fact that the tub is higher than the tank, it will allow it to fill w/o backing up.
the bottom of the shower is on top of the floor; the tank is beneath the floor; therefore, the top of the tank is lower than the bottom of the shower. water will seek its own level, so it WILL go into the tank, even if the pipe doesn't enter at the top. (as long as the top of the tank is vented, so air on the top can escape). The shower may drain slower as the tank fills...but it will drain.
so, is that a stock tank in your drawing? make/model# dimensions? Andre is going to put a grey tank in my 73, too, so he needs to know which one to buy.....
It will. I did the experiment with my blue-boy...I had it slung in my spare tire carrier, and ran a hose (piece of pex pipe) from the sewer outlet all the way up front to the blue-boy, where it entered at the bottom of the blue boy. It worked. and I didn't even notice any slowness in the draining. I decided that the whole thing was just too low to the ground for my taste, and generally more trouble than it was worth.
proof of concept, though. you can fill a tank from the bottom, as long as whatever is draining is above the top of the tank.
Great!
I actually started the grey tankology thread and discussed it there before I ordered it.
I was still a little worried though. Thanks for the info on your test!
Todd...
The tank you're looking at is proabably strong enough to hang from the side. I don't think the Al-Rite tank I had made would be. However you mount it, I would make sure you can remove it from below for servicing.
call the 800 number real nice guy named chris runs the phones... tank was about $50 cheaper than anywhere else that i could find.... i need to save some money for the custom black tank that i will have all-rite make
good deal! i was thinking about doing some kind of T off of the main drain instead of drilling another hole in the tank if it was possible to fill from below the water line...
