Old 12-08-2019, 11:42 AM   #1
2004 25' Classic
Hanahan , South Carolina
Strange dump valve size?
I have an 04 Classic 25’, new to me and am attempting my first dump...
It came with a new Camco hose and a used Rhinoflex hose. Neither fit...
It did have an adapter “thetford” that will connect to the camper, it will also connect to the discharge side of the hose but seems a little large to slide into the hose with a clamp.
I went to camping world to try and get an adapter but they do t have what I need in stock.
Is an 04 an odd size or was mine adapted? And any suggestions on what next?
Planenut is offline   Reply With Quote
Old 12-08-2019, 04:18 PM   #2
2019 22' Sport
High River , Alberta
Yes, the Thetford fitting seems a bit large. The hose will go on, but you will need to work at it.
Try dropping the end of the new hose in bucket of hot water.
Having owned both (and having rebuilt a pair of old Thetford valves), I’m happy with Valterra.
AlbertF is offline   Reply With Quote
Old 12-08-2019, 05:08 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
You will have to do one of two things. Either use a Thetford sized hose end or get an adapter.
https://www.etrailer.com/s.aspx?qry=...lterra+adapter
https://www.amazon.com/Valterra-T05-...57931278&psc=1
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 12-08-2019, 05:37 PM   #4
2004 25' Classic
It gets better, NOT.
See post #4
http://www.airforums.com/forums/f444...sh-203316.html
Old 12-09-2019, 06:36 PM   #5
Long time owner
2004 25' Classic
1974 25' Tradewind
1970 21' Globetrotter
1975 26' Argosy 26
Forrest City , Arkansas
I also have a 2004 Classic and this summer I decided to purchase the Rhino Extreme dump hose. It did NOT fit. I came to find out that I would need an adapter that is sold by the Airstream Store. It is inexpensive. I was told that AS units before like 2008 have a different size than the newer models which converted over to the industry standard. Call the Store or go online to get it.
doctorlewis is offline   Reply With Quote
Old 12-09-2019, 07:04 PM   #6
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
You can also buy a Valterra pipe fitting, cut the old Thetford fitting off and glue on the Valterra. When we picked up our 2002 Classic (trading our 2001 Safari which had a Valterra valve added after the two original valves) I moved my Camco hoses over to it but discovered they didn't fit. The dealership didn't have the adapter, but a Camping World on our route had the end fitting. I stopped in a Home Depot and bought a Dremel Tool to cut the old fitting off and some glue to glue the new one on. I changed it in the parking lot, in the cold, in the rain; but we could dump on the way home.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Copper pipe from water heater - strange size? 69 safari 69airstream Water Heaters, Filters & Pumps 15 11-12-2015 08:17 PM
Dump Valve Size on '77 Safari? AldeanFan Waste Systems, Tanks & Totes 0 06-15-2013 08:45 PM
Strange Blackwater Tank/Dump Valve glang58 Waste Systems, Tanks & Totes 1 08-02-2010 01:27 AM
Dump Valve Will Not Open Darryl Waste Systems, Tanks & Totes 1 06-19-2002 01:19 PM
Dump valve gwsullivan Waste Systems, Tanks & Totes 11 05-30-2002 09:38 AM
